leveling kit question
Old Jul 8, 2009 | 09:39 PM
mstngmikegt's Avatar
mstngmikegt
Curious to see before and after pics too.
Old Jul 9, 2009 | 08:58 AM
mike242424's Avatar
mike242424
ill be sure to post them as soon as its done i ordered everything they say 5-10 business days so well see how quickly it gets here and i can get it done.
Old Jul 9, 2009 | 05:12 PM
1966Tbird's Avatar
1966Tbird
here is a pic with spacers and 33s
Old Jul 10, 2009 | 07:06 AM
BuickBrian's Avatar
BuickBrian
1966TBIRD,
What kind of alignment changes did you have to make when you added the spring spacers in the front? Being a engineer, I sat down and did some quick trig calculations based on the length of the front beams and the amount of change in height (1.5" is what I was looking to do), and I found that the camber will change by 2 degress by simply raising the truck by 1.5" in the front. Mine came from the factory with the max angle bushings in it (1.5 deg), so I don't see how I could ever get it back right if I raised it. It would take a 3.5 deg bushing to do it!
Old Jul 10, 2009 | 10:50 AM
Shanemh's Avatar
Shanemh
I put a daystar leveling kit on mine. Simple. They are red spacers that just sit underneath the spring. Didn't need spring compressor. Just jack the truck up somewhere that when you lift it up, the spring is extended out as much as it can. Then the springs just come in and out with no issues at all.
Old Jul 11, 2009 | 11:09 AM
1966Tbird's Avatar
1966Tbird
yes you need to get aftermarket camber bushings and they work but my camber is still off by like half a degree or something it's not noticable unless you are doing over 120mph then the truck starts to get a little twitchy but it's a 4wd truck with 33s it shouldn't go over 120 (yes i have had my speedo wrapped all the way to 25mph one time)
Old Jul 24, 2009 | 05:12 PM
mike242424's Avatar
mike242424
picture troubles
I was planning on posting a before and after picture of my truck w/ the leveling kit but i cant seem to find where you post pictures on. I went to faq and it said go to post reply rather then quick reply and go to manage attachments. That isn't showing up on my computer. can anyone help me? thanks alot
Mike
Mikes92F250
Mar 13, 2012 10:37 PM
mike9254
Jan 7, 2010 11:45 PM
MIKE 04 GT
1997 - 2003 F150
Jan 23, 2009 10:33 AM
da cubs
1997 - 2003 F150
Mar 30, 2003 05:09 PM
