Leaky tank
Old Jul 1, 2009 | 07:13 PM
laworange78's Avatar
laworange78
Leaky tank
Does anyone know of a way to half *** seal up a small leak on my gas tank till i get a new one. Where would should i get the new tank at?
thanks
Old Jul 1, 2009 | 07:55 PM
Jermafenser's Avatar
Jermafenser
JB weld.
Any of the sponsors right here on FTE.
Old Jul 1, 2009 | 08:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The tank repair kits found just about anywhere actually do a pretty decent job as long as the leak isn't on the very bottom with all that weight sitting on top of the repair.
Josh
Old Jul 2, 2009 | 05:42 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Depends on where it is, and how bad. If its a 4 wheeling/Rock Crawling gash, not to big, I have heard, LOL, of trimming a piece of soft wood to wedge in there to slow the flow.
If its a rust area leak like from under the bottom support straps where the rubber
anti-chaff material has worn off. Drop tank, clean the heck outa that spot, down to bare metal.
CAREFUL USING A ABRASIVE GRINGING WHEEL/SPARKS GAS FUMES DO NOT MIX!!
And JB weld the heck out of it, replace the worn rubber pad material (old inner tube will work).
Old Jul 2, 2009 | 07:35 AM
jimlj's Avatar
jimlj
Years ago I drained the tank, cleaned the area and used JB weld, with a piece of plastic milk jug stuck to the glue over the rust hole. That "fix" lasted several years while I owned the truck, and as far as I know is still holding.
Old Jul 2, 2009 | 10:06 AM
Witty73's Avatar
Witty73
This is going to sound odd, but years ago my bro poked a 5/16 inch size hole in the bottom of the tank. Gasoline was running out in a steady stream. My grandfather came out with a tube of "seal-all" glue he used to rave about that he got at the grocery store. It claimed you could patch gas tanks. So he took a big gob of that stuff, and smeared it over the hole while the gasonline was running out. I laughed at him and jokingly accused my grandfather of being senile. That tank is holding gasoline to this day.
breedo99
13
Mar 25, 2010 09:07 PM
Terpfords
Mar 25, 2009 12:41 PM
cobraii
Sep 23, 2003 08:49 PM
SDawgz
Garage & Workshop
13
Jun 28, 2003 02:59 PM
billb7984
1947 and Older Ford Trucks
Jun 7, 2003 02:52 PM
