well it definitely is going to be clutch time this year. does anyone have step by step procedure for 93 7.3l clutch replacement. guess I am going to need to do the rear main seal also. started slipping in third, and I am getting shaking and shuddering at startup. Guess I will go with the solid luk flywheel.
I don't have a transmission jack, do any autoparts stores rent them. any advice is well appreciated. I am not looking forward to doing this. is there anything else i need to do while doing this. my rear main has been leaking for years.
no just at an idle, when you give it a little gas at an idle it goes away. sounds fine when driving. shakes bad when you first start and sitting there.
X2 what Dave said. When the stock flywheel went bad in my son's 97, it would shake with no ryme or reason. It did not slip or rattle. When we changed it out we found the center bearing was going bad.
