engine codes 553, KOER 312, 225
Old Jul 1, 2009 | 08:13 AM
thegreatbriguy's Avatar
thegreatbriguy
I've got a 4.9 L with a manual. I'm trying to decifer these codes.
553 Air Management 2 circuit failed, SBS circuit failed....what is this?
312 thermactor air was misdirected. what is the thermactor
225 something with the knock sensor?
thanks a lot.
Brian
Old Jul 1, 2009 | 10:46 AM
alxsnmr's Avatar
alxsnmr
What year is the truck?
It is related to your Air injection system I believe it is the diverter that directs air to the head or to the cat.
Thermactor is your Air injection system.
Either check to make sure your knock sensor is plugged in or even working properly. Only problem is someone with a 4.9 or knows more about them than I will have to tell you where the KS is located. Use Fordfuelinjection.com to learn how to test the KS.
Old Jul 2, 2009 | 08:07 AM
thegreatbriguy
Sorry, it's a 1991.
ok, i found the thermactor on fordfuelinjection.com, i must not have looked at the right place before. I'm thinking it is off the smog pump, the second diverter, from what i understand? I will try to find one at the junk yard and swap it out.
Old Jul 2, 2009 | 08:31 AM
alxsnmr's Avatar
alxsnmr
They can be purchased brand new, but there are different versions of the diverters. One diverter is 2 in one, another has the muffler built into it, yet another is looks the same for the TAB and TAD. Since it is a 91, the only sensor is if the computer gets a rtn signal from the switch ontop of the motor. I would check to see if they are plugged into the wiring harness, if not it may be just a bad switch.
88 f150
Sep 23, 2021 07:55 AM
Ed Bamba
Jan 27, 2015 09:21 PM
stanglver1511
Oct 29, 2013 09:11 AM
f100beatertruck
Jul 29, 2013 07:41 PM
dbuck50
Oct 30, 2003 01:54 PM
