Code 311-Thermactor air system inoperative
Old Oct 29, 2003 | 02:59 PM
dbuck50's Avatar
dbuck50
I can't lose this code and can't diagnose the problem.
I have replaced the Thermactor air pipe, the check valves (both of them, and tested the air bypass valve...they all functioning. Is there something else I can test/try to clear this code? I'm thinking this has something to do with me not passing the smog test.
Old Oct 30, 2003 | 12:31 PM
dbuck50's Avatar
dbuck50
OK, no bites. How about any problems related to the air pump or the black valve thing that comes right after it? I'm starting to guess that the inactive code means it's not working at all...like no air?
I think the TAB/TAD solenoids factor in here too...anyone have that experience?
It seems to run better (smoother idle)when I advance my timing to 16 degrees...I don't know if that will make my smog test better or worse.
Old Oct 30, 2003 | 01:54 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
There is a long involved troubleshooting guide in the book for the air system. If you can get your hands on it somewhere, that would be your best bet. I don't have any personal experience that would benefit you on this, sorry.
SJP
Mar 18, 2016 08:24 PM
Grems4ever
Nov 18, 2015 09:02 PM
bigkeeser
May 8, 2008 01:25 PM
greystreak92
1978 - 1996 Big Bronco
Apr 28, 2005 07:17 PM
chetv10
30
Oct 28, 2003 02:37 PM
