Injector upgrade question...
Old Jun 29, 2009 | 08:01 AM
Brown Falcon's Avatar
Brown Falcon
What injectors would be best if going with a stock turbo or a D66 turbo setup?
I think 2's would be too much... Stage 1's as big as I should go?
Old Jun 29, 2009 | 08:45 AM
redone1's Avatar
redone1
I really don't know...But I'm going to upgrade to DIY stage 2's and only run them at stage 1 capacity for now. I've bee told this is doable since the chip will control the injectors. Might as well put stage 2's in and not have to pull injectors later on if you decide stage 1 isn't enough.
I plan on doing the supporting mods down the road in order to utilize the stage 2's, but I'm not sure what all mods will be needed.
Old Jun 29, 2009 | 09:07 AM
Brown Falcon
I wouldn't be going any bigger than a D66 turbo. Don't want to shell out the money for a H2E setup.
Just a daily driver and maybe some fun at the drag strip every once in a while.
Old Jun 29, 2009 | 10:53 AM
Neal 97 250's Avatar
Neal 97 250
The II's will definately produce more than 30 psi at any given time. The d66 and stock turbo do not like greater than 30 psi.
I ran my II's with the stocker for quite a while and yes it will take it but not for long. I tried to be easy on mine and it wasn't damaged when I removed it.
Old Jun 29, 2009 | 10:58 AM
Brown Falcon
So I'd be better off getting Stage 1's I'm thinkin...
How much boost and HP/Torque can the 1's produce? Stock and d66?
Old Jun 29, 2009 | 11:10 AM
Neal 97 250
If you onlyt plan on stock or d66 turbo I would stick with I's
Especially if you don't want tranny problems. The tranny will not hold II's at all.
Old Jun 29, 2009 | 12:01 PM
Brown Falcon
Yeah, I've got a rebuilt tranny in mine right now with about 2k miles on it so far. I figure if it's still running good when it goes out I'll get a new better transmission.
Old Jun 29, 2009 | 12:46 PM
Neal 97 250
BTS is the way to go but you are looking at $4000.
Well worth the money though.
Old Jun 29, 2009 | 01:17 PM
Brown Falcon
how much more does a H2E setup go for than a D66?
Old Jun 29, 2009 | 01:36 PM
Neal 97 250
$2400 H2e verses $1125 D66
Old Jun 29, 2009 | 02:04 PM
Brown Falcon
rough estimate of HP/Torque Intercooled D66 Stage I's vs Intercooled H2E Stage II's???
Old Jun 29, 2009 | 02:17 PM
Neal 97 250
I will be able to get you the second part of that equation in about a month. Muuuuhahaha
MattHall
21
Nov 4, 2014 02:02 PM
kyle j
Oct 12, 2013 12:58 PM
holdtyte
Aug 26, 2012 03:05 PM
1979BEAST
62
Sep 28, 2010 05:58 AM
Suber
54
Sep 18, 2007 02:13 PM
