Electrical Problems
Old Jun 28, 2009 | 12:39 PM
Holiver31's Avatar
Holiver31
Electrical Problems
Hey guys, I thought I had all of my electrical problems solved for awhile but they have come back to haunt me. My temp. and oil pressure gauge fluctuate whenever the lights are turned on. And my door buzzer turns on as well whenever the lights are on, if you turn the **** as if you were dimming the gauge lights the buzzer responds to it. It sounds like a ground problem to me. Does anyone have a list of grounds pertaining to the dash and its components?
Old Jun 29, 2009 | 06:50 PM
Holiver31's Avatar
Holiver31
bump...........
Old Jun 29, 2009 | 06:54 PM
fmc400's Avatar
fmc400
MSEE
Hmmm...the seat belt buzzer adjusts with the dimmer? Can't say I've run across this one before. A ground problem is possible, but I don't think it's the case here. I think there is a short with the dash illumination circuit; most likely on the printed circuit board itself. The circuit you're hunting is a blue wire with a red stripe; find where it connects to the circuit and look around the back of your gauge cluster for shorts.
Old Jun 29, 2009 | 09:57 PM
Holiver31's Avatar
Holiver31
Thanks fmc, turns out that there was 1 ground that had shaken loose back behind the dash, and where it connects to the circuit was pretty corroded. No more buzzer issues either. Thanks.
Chea77F150
Dec 22, 2014 09:30 AM
reamer
Jun 4, 2014 11:36 AM
GreatNorthWoods
Jun 19, 2012 03:12 AM
anthony605
Jan 4, 2004 08:17 PM
gordond
Jul 5, 2000 01:24 AM
