Strange Dash Issue
Old Dec 20, 2014 | 06:48 PM
Chea77F150's Avatar
Chea77F150
Strange Dash Issue
For the last year or so I have been having an issue with my dash lights. The issue is that when I pull my headlight switch out to turn on my headlights all of the following happens: the seat belt buzzer sticks on at a low tone, the background dash lights become so dim you can hardly see the gauges, both turn signal lights become dimly lit, and my fuel gauge moves all the way to the right showing that I have over a full tank. When I hit the high beam switch on the floor to turn on my brights the buzzer gets louder. Also, when I use my turn signals the buzzer becomes louder whenever the flasher cycles.
From time to time the issue will suddenly go away and all of the dash lights come on like normal.
Anyone ever have this issue? Any idea as to what is going on? I am not sure where to start.
Old Dec 21, 2014 | 08:28 AM
fordguy62's Avatar
fordguy62
Check all your grounds and connections.
Old Dec 21, 2014 | 09:28 AM
bertha66's Avatar
bertha66
As above check your grounds. Also, have you pull the dash and looked at the gauge cluster? the old plastic backing maybe coming a part and the printed circuit maybe shorting out.
Old Dec 21, 2014 | 11:31 AM
Chea77F150's Avatar
Chea77F150
I will check grounds and check the circuit board. Question though, where are all the grounds located for this system?
Old Dec 21, 2014 | 12:13 PM
Chea77F150's Avatar
Chea77F150
"Y" Brace
Does anyone know what the Y Brace is?
Old Dec 21, 2014 | 12:22 PM
Tedster9's Avatar
Tedster9
The easiest thing to look for is any additions that someone may have added for stereos or CB or whatever. Tapping into any wire that's "hot" without regard to current handling for example. You've got a ground problem alright - a short to ground sounds like.
Old Dec 21, 2014 | 03:19 PM
Chea77F150's Avatar
Chea77F150
Bad connection
Figured it out. I took the instrument panel out and looked at the contacts, everything looked good so I put it back in and turned on my headlights. It was doing the same thing so I decided to see if I could wiggle the connection and sure enough the harness connection to the cluster has enough movement to where it causes a poor connection. I wont be able to scrounge around for a replacement anytime soon so do you guys think I can put a little dielectric grease on the contacts to help me get by?
Old Dec 21, 2014 | 04:49 PM
Tedster9's Avatar
Tedster9
What kind of connector is it? Without knowing exactly, try cleaning it out well with a solvent, maybe crimping the parts so good positive contact. Dielectric just keeps corrosion and moisture away. Glad you found the problem!
Old Dec 22, 2014 | 08:11 AM
bertha66's Avatar
bertha66
I would just try to tighten up the contact area of the plug-in and clean the contacts.
Old Dec 22, 2014 | 08:36 AM
Chea77F150's Avatar
Chea77F150
Thanks guys, I put some dielectric on it and put it back as snug as possible. The connection is where the harness plugs into the back of the cluster to the circuit board. The material to the cluster is crumbling so I can't do anything to fix it other than replace it with one from a newer Econoline or aftermarket.
Old Dec 22, 2014 | 09:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The POS composition material cluster back is TURNING TO DUST before my very eyes, so I can't do anything to fix it other than replace it with one from a newer Econoline or aftermarket.
SAME hard plastic cluster backs, were also the "service part replacements" for the POS originals (1975/79 F100/350, 1975/80 Econoline, 1978/79 Bronco).
E1PZ-10848-A .. Hard Plastic Cluster Back - 1981/91 Econoline with Oil/Amp GAUGES.
E1PZ-10848-B .. Hard Plastic Cluster Back - 1981/86 Econoline with Oil/Amp WARNING LAMPS.
Available NOS from Carpenter.
greenmachine86
15
Aug 28, 2016 07:10 AM
Scrpmny
Apr 20, 2015 09:03 AM
eb76adam
Dec 4, 2012 10:29 AM
catbird7
Electrical Systems/Wiring
Mar 29, 2006 03:59 PM
77traded
Mar 27, 2005 06:57 PM
