Engine idle problem when hot
Old Jun 27, 2009 | 10:13 AM
Flobber's Avatar
Flobber
My truck does idle weird when at normal temp ! both gauge Oil temp, water temps at 180. When I am at a stop sign it just mist to almost die. when it does that there is a small puff of black smoke coming out the pipe.
EGR deleted.
I suspect Fuel Filter again, they were change summer 2008.
Even when I drive steady lets say 60mph I can feel that something is not right. Steady pedal and it accelerate by himself a bit and then come down.
Any clue?
preparing to change filters again.
Thx
Old Jun 27, 2009 | 11:04 AM
bismic's Avatar
bismic
How many miles did you go since the 2008 filter change. You MUST change it at 15k intervals MAX! - Preferably 10k. Otherwise you risk injector repair bills.
Old Jun 27, 2009 | 12:52 PM
69cj's Avatar
69cj
Not knowing the build date, it could also be an STC or HPOP problem since it is only after the engine is warm.
