Tranny Line Instulation
Old Jun 25, 2009 | 10:08 PM
kawa's Avatar
kawa
After I converted my tranny lines from 5/16" to 3/8" I realized that the lines were less than an inch from my down pipe. They needed to be shielded from the heat by some method. I ruled out making a sheet metal barrier as just a big PITA.
I was at a large plumbing store today and found a product called "Flame Stopper" it is comprised of aluminum foil with a white cotton/matting like material affixed to one side of the foil. It is normally used to protect flammable surfaces from torch flame during brazing & soldering copper tubing etc. It measures about 11 inches square. It's made in the good ole' US of A and is asbestos free.
Months earlier, I had purchased some stainless steel cable ties from Harbor Freight #92515. (made in China)
I cut a strip of the foil about 41/2-5" wide then removed about 3/4" of the "Cotton" from each side and on both ends. I then laid it lengthwise on the tranny line and wrapped it around the line as tight as I could, Then I used three (3) SS cable ties to secure it, cutting off the excess and folding it back to lock them in place.
I found that once I had the foil wrapped and secured I could shove/slide it over and around any bends all the way up to the fitting. This one piece of material covered my whole job.
I took a chunk of the matting and laid it on my vise and fired up a propane torch and the flame never discolored, melted or in anyway effect the matting. I couldn't find the receipt for this material but I think it was around $8-$11.00 for the sheet.
Rog
Old Jun 25, 2009 | 10:18 PM
Talyn's Avatar
Talyn
neato job rog!
Old Jun 26, 2009 | 12:29 AM
pjwoolw's Avatar
pjwoolw
Very nice Rog! Going on the to do list.
Old Jun 29, 2009 | 11:44 AM
aaron ford's Avatar
aaron ford
Did you see any diffenerce with the 3/8 inch lines? My tranny shifts with the phases of the moon, completely independent of RPM and load with factory lines and cooler. Anything to note?
Aaron
Old Jun 29, 2009 | 12:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Rog, I tried to rep, but you know
Do you have any pics of the original material and the finished job?
Old Jun 29, 2009 | 12:37 PM
kawa's Avatar
kawa
Jose, No I don't. In the beginning I didn't know if it would even work so iIdidn't take any pix. I could go by the store a shoot a pix of the product and I can still crawl under the truck for the photo. The completed wrap looks much like a sheet of aluminum foil wrapped around a 3/8's line and "smooshed" with your hands.
I'll see what I can do for pix.
Rog
Old Jun 29, 2009 | 01:00 PM
kawa's Avatar
kawa
aaron:
I haven't noticed any difference in shifting and really doubt that a shift change would be effected. The conversion, as I understand it is strictly for fluid flow and an aid in cooling. Any residual effects above and beyond that would be completely out of my scope of knowledge.
Rog
Old Jun 29, 2009 | 01:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Rog
Ok, thank you.
Old Jun 29, 2009 | 01:31 PM
Brown Falcon's Avatar
Brown Falcon
I noticed my tranny line is a little close to my new downpipe... might just put some header wrap around my DP near there.
Old Jun 29, 2009 | 02:10 PM
Pest007's Avatar
Pest007
I put foil on mine a long time ago, lol!
Old Jun 29, 2009 | 03:21 PM
Cuda_jim's Avatar
Cuda_jim
I just re-used the insulation off the flattened DP.
A rubber hammer and a couple minutes time and it looked like it belonged there . I used stainless steel header straps left over from another project to fasten hold it on but it could be wired too IMO.
Old Jun 29, 2009 | 08:22 PM
pjwoolw's Avatar
pjwoolw
Insulation stuff
Here is a link to some insulation and reflective products.
Old Jun 29, 2009 | 09:32 PM
aaron ford's Avatar
aaron ford
Thanks Kawa, I guess I was hoping that my plugged cooler was causing my shift problems....
But since I poked a hole in it getting it off to flush it out, I will be installing a tru-cool with bypass.
I would like to install 3/8 but the radiator cooler lines would be my limiter. I am curious if the outlet and inlet on the transmission are NPT threaded. How did you convert them to the 3/8?
Anyway, armed with your post, I climbed up underneath and found a similar situation. My exhaust runs within 1 inch of my tranny lines as well. I had never noticed that before. I will be insulating with your pipe wrap.
Thanks,
Aaron
Old Jun 30, 2009 | 01:49 AM
kawa's Avatar
kawa
Patrick, there are many great items in their catalog but no pricing. You have three 930 distributors in CA. so I guess we would have to call to find out pricing.
Thanks for the info.
Rog
david.brady
Jan 18, 2015 07:46 PM
swirk
Jul 23, 2013 11:29 PM
JWA
Jan 12, 2013 05:41 AM
kawa
Jun 25, 2009 10:30 PM
HJCartman
1978 - 1996 Big Bronco
Apr 1, 2006 09:42 PM
