Gpr led
Old Jun 25, 2009 | 08:58 PM
jt371's Avatar
jt371
______
Gpr led
Just did the GPR LED in the cab install. Used a little green LED from Radio Shack. I drilled a hole on the left of the steering column just big enough for the LED to be pressed it. (heard about that trick on here) Ran a ground and a hot wire to the output of the GPR. I used quick dissconnects on the back of the LED so if I ever need to remove the front of the dash, just unplug rather than cut and resplice. Can't believe how long it stays on after WTS light goes out. But atleast I know for sure that it is working.
I plan to do the TC lock up and EBPV/Brake soon. Just need to get the required info and parts to do the install. I have found a couple of write-ups on the TC lock up but they require building a fooler for ECM. Anyone have and experience with this method or just wiring it direct?
Old Jun 25, 2009 | 09:27 PM
danskool's Avatar
danskool
Go Bills !
GPR LED is on my list. Thanks for reminding me to stop at radio shack for LED's..
My quick sketches of how i did TC lock and EBPV brake(in case i had to trouble shoot). So excuse the messiness. I put Led's in my gauge pods..
EGT gauge carries the Led for the EBPV brake, activated
Trans Gauge carries the led for the TC lock, Activated.
Old Jun 25, 2009 | 09:52 PM
jt371's Avatar
jt371
______
Thanks for the diagrams. Thats what I wanted to see. I have read a couple descriptions of how it is done, but I like pics they are easier to understand exactly whats going on.
timmyboy76
Mar 24, 2014 08:00 AM
MiamiPSD
Mar 7, 2013 07:25 PM
bigbubba87
Sep 12, 2010 11:07 PM
Liquid10Rider
15
Jul 8, 2010 08:32 AM
bdrummonds
20
Dec 20, 2008 01:41 PM
