Options to widowmakers...
Old May 16, 2016 | 12:10 PM
  #31
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
I think you'll find your answers here. TN is a Merc M-7, 81 is a conventional cab, B is the deluxe cab called a "5 Star Extra", H is left hand drive, 51 is 1951, 5005 is the unique serial number. Stu
https://www.ford-trucks.com/forums/1...fo-thread.html
Old May 16, 2016 | 12:34 PM
  #32
daveheld's Avatar
daveheld
thank you again... the other number quoted by the seller as the VIN is
7E 9Q 5005-B
Looking for info on the transmission... E indicates 239 cu in
but Q indicates 337 cu in - which makes more sense being a mercury
5005 is consistent with the other Serial number
The pics show it as yellow.. which is consistent with the 51 (but that's also the year)
not sure if i'm more or less confused... but at least it's more info to go on
thanks again for the info
dave
Old May 16, 2016 | 12:40 PM
  #33
truckdog62563
The engine should be a 337, assuming Canadian specs are the same as US. The 239 was only used through the F-6. The rest of your number needs input from the experts. Stu
Tul01
22
Dec 21, 2017 05:23 PM
Tree_Farmer
Large Truck
Nov 1, 2017 05:23 PM
FordsOnlyGarage
Jun 15, 2017 07:05 PM
ShovelheadDan
38
Apr 25, 2017 05:15 PM
Bowsandovals
19
Jun 25, 2016 06:49 PM
