Loss of oil pressure
There is no Stock Monitoring System for the HPOP System.
The Oil Pressure Gauge on our vehicles monitors the Low Pressure or Engine Lubrication portion of the System.
It is possible to have a Low Pressure Pressure issue and still supply Oil to the HPOP.
I would begin by putting a Mechanical Gauge where the Sending Unit is an monitor. at a MINIMUM you require 12 psig at Idle to facilitate sufficient Lubrication.
If that "Passes the Test". Check the Sensor, Connector, Wiring, and suplimental Connections until you identify the problem.
The Sending Unit is atop the HPOP Reservoir as stated. Part# 9378
Q: Why would the oil pressure be normal at start up and then drop all at once.
A: A defective Sensor, failing Oil Pump, Viscosity Change.
Q: Revving the engine has no affect on the pressure reading.
Q: At start up the gauge immediately goes to mid range on the gauge.
A: These are Analog Thermistor Units. They do not graduate in small increment. The generally sweep from, for example: Mid Range to HOT on Cooling - They're not graduated, they either are, or are not.
jeffbradbury7
01-19-2013 08:37 AM
