Loss of oil pressure
Old 12-30-2017, 03:01 PM
buckshot1537's Avatar
buckshot1537
buckshot1537 is offline
I have a 2002 F250 7.3 that after starting and letting it run at idle the oil pressure gauge will drop to 0 and the check guages light will come on. usally happens after 2 to 5 minutes of running. Truck is full of oil and continues running.
Old 12-30-2017, 03:22 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
If the truck is still running you have oil pressure. HEUI injectors need high pressure oil to work. No oil pressure, no run. Need to check gauge for proper operation.
Old 12-30-2017, 04:22 PM
buckshot1537
that was my understanding , that it would shut down if it lost oil pressure. This is my first deisel
Old 12-30-2017, 04:41 PM
hydro man 17
Yes that is the case with our HEUI engines. I don't know if there is a fail safe of some sort on the peizo electric version.
Old 12-30-2017, 06:17 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
There is no Stock Monitoring System for the HPOP System.
The Oil Pressure Gauge on our vehicles monitors the Low Pressure or Engine Lubrication portion of the System.
It is possible to have a Low Pressure Pressure issue and still supply Oil to the HPOP.
I would begin by putting a Mechanical Gauge where the Sending Unit is an monitor. at a MINIMUM you require 12 psig at Idle to facilitate sufficient Lubrication.
If that "Passes the Test". Check the Sensor, Connector, Wiring, and suplimental Connections until you identify the problem.
Old 12-30-2017, 09:16 PM
buckshot1537
where is the sending unit
Old 12-30-2017, 09:20 PM
buckshot1537
why would the oil pressure be normal at start up and then drop all at once. reving the engine has no affect on the pressure reading. at start up the gauge immeditly goes to mid range on the gauge
Old 12-30-2017, 09:22 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
The sensor that's atop the hpop resivoir...get yourself a #4orb(m) X 1/8npt(f) adaptor from a hydraulic shop. Then get a liquid filled 100psi gauge and a 9" grease gun hose. Acquire a 1/8npt coupling and now, you have yourself an oil and fuel pressure tester
Old 12-30-2017, 09:25 PM
buckshot1537
would that check the low pressure issue mentioned above
Old 12-30-2017, 09:35 PM
timmyboy76's Avatar
timmyboy76
Absolutely....
Old 12-30-2017, 10:37 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
First thing that comes to mind is low voltage or a stall/stutter?
Do you notice a stumble, or a quick catch to keep running when this happens?
Old 12-31-2017, 08:36 AM
pirschwagon
The Sending Unit is atop the HPOP Reservoir as stated. Part# 9378
Q: Why would the oil pressure be normal at start up and then drop all at once.
A: A defective Sensor, failing Oil Pump, Viscosity Change.
Q: Revving the engine has no affect on the pressure reading.
Q: At start up the gauge immediately goes to mid range on the gauge.
A: These are Analog Thermistor Units. They do not graduate in small increment. The generally sweep from, for example: Mid Range to HOT on Cooling - They're not graduated, they either are, or are not.
Old 12-31-2017, 09:41 AM
buckshot1537
a final question. would it be safe to drive or am I going to burn the engine up??
Old 12-31-2017, 12:15 PM
hydro man 17
I would certainly insure that I had verified readings before doing any serious driving.
Jonathan Martin
07-08-2019 07:05 PM
jeffbradbury7
01-19-2013 08:37 AM
lapwrstroke
1999 to 2016 Super Duty
06-18-2010 09:28 PM
imfinethanx
1997 - 2003 F150
01-18-2008 08:56 PM
rboss
10-29-2003 07:58 AM
Quick Reply: Loss of oil pressure
