Rear Main Install With Wear Ring, Easiest Way To Install?
While cleaning up my motor for reassembly, I noticed that I have a worn groove in the rear main of my crank shaft.
Fortunately, the new rear main seal includes a wear ring.
I'm a bit torn on the best/easiest way to install it.
Motor is out of the truck, so I have space for activities. Do I need the expensive tool? I was sort of thinking I could get the wear ring started GENTLY with a mallet, and maybe pull it the rest of the way on with the flywheel?
Do I need to use anything like a retaining compound on the ring?
Thank you!
Ouch.
Thank you!
Ouch.
The ONLY right way is to use the proper tool. Trust me. Also, as per the instructions that should have come with it: A.) yes, you need to use retaining compound. The same stuff as used on injector cups will work. Also, use the International/Ford grey "super goop" on the aluminum flange to the block surface.
B.) Also,as per instructions, NEVER remove the wear ring from the seal. It should have come pre-assembled in the package, with the ring already inside the rubber seal. Leave it that way. If you already took it apart, get a new one.
This is form my Clutch and related items thread:
https://www.ford-trucks.com/forums/1...-and-tips.html
Rear Main Seal w/ wear ring:
$47.88 at local dealer - again price matched w/ Tousley (list-34%, or cost+10%)
Ford Part# F4TZ-6701-A
It will come with an large re-sealable tube of the International grey "goop" RTV- way more then you need for the seal. Yay, free grey goop....
Sleeve Retaining Compound:
Same as what would be used on injector cups. This goes on the inside bore the wear sleeve, to keep it from rotating on the crank in operation.
I used green Permatex 640, which I got from Napa, and had left over from doing my cups. LockTite 640 will work too, I believe. It just has to be Sleeve Retaining Compound, NOT thread locker.
https://www.napaonline.com/napa/en/p/BK_7651149/
https://www.amazon.com/Loctite-37424.../dp/B0002KKTIG
Rear Main Seal and Wear Sleeve Install Tool:
You WILL need this to install properly. Buy, Borrow, Rent, whatever.
This one is a complete set, including the parts needed to remove an existing wear ring, if the seal has been replaced before: OTC Part# 7835 $313.11 from Amazon.
https://www.amazon.com/gp/offer-list...&condition=new
Installer tool only, will not remove an existing/old wear ring:
These guys will also "rent", but its costly, as you only get a 50% refund
Freedom Racing Part# 303-S485
303-S485 Crankshaft Rear Oil Seal Installer T94T-6701-AH Alt.
The tool isnt really neceasary but its nice to have. I have never used the tool and ive done a few of them, i just use the old wear ring and cut half ways the ring so it wont get stuck and use a piece of 2x4 and strike it with the hammer, has worked great and never had a failure.
2.) If it does already have one, how do you remove it without the tool and without damaging the crank?
3.) Why take the chance? Getting it wrong and having a leak means a LOT of work to pull the trans and do it again, along with the chance of a ruined oik-soaked clutch.
holdendaniels
12-04-2010 08:51 PM
