Who has headers?
Old Jun 21, 2009 | 12:48 PM
F-250 restorer's Avatar
F-250 restorer
Who has headers?
All I read on the forum is about people with leaks and problems with their headers.
Please let me know if you have had a good experiance with headers, and what you did to prevent leaks and bolts/studs loosening up.
I am getting ready to drop a rebuilt 300, and have a hedman dual outlet header. I'm trying to decide if I should switch to the EFI exhaust manifold.
Any feedback is appreciated.
Old Jun 21, 2009 | 07:16 PM
jmteam6's Avatar
jmteam6
I have had headman headers and a clifford manifold for over 3 years now or about 60k miles with not leaks so far. The only thing I did extra was to use spary copper on both sides of the gasket and run the engine about 30 -60 minutes let it cool enough so I would not get burned and retighten the mounting bolts. Just make sure that the header mounting flange is true to the head mine was off by about 1/8" and had to use a pipe wrench to straighten it.
Old Jun 21, 2009 | 08:02 PM
F-250 restorer
spary copper...
what is that?
Thanks for the info.
Old Jun 24, 2009 | 08:36 PM
jmteam6's Avatar
jmteam6
It is a spray on copper based product designed to help seal and dissipate heat on exhaust/intake manifolds and gaskets it also works great as a anti seize for your exhaust bolts that have a habit on rusting and getting stuck. I got mine from NAPA auto parts but have seen in other stores too. I believe it is made by permatex usually found near exhaust system parts. I put 2 coats on both sides of the gasket and let it set overnight was still tacky next day when I installed it and have not had any issues.
Old Jun 24, 2009 | 10:02 PM
Harte3's Avatar
Harte3
What jmteam6 said plus it's probably not a bad idea to retorque the studs/bolts after you have ran it and had it up to operating temps for a bit.
Old Jun 26, 2009 | 10:59 PM
optikal illushun's Avatar
optikal illushun
i soaked the header gasket in water for a short time and used the copper spray on both sides. supposidly soaking em in water works, so i tried it. i also let the engine warm up a few heat cycles and retorque the bolts. no leaks thus far.
SDF350HUFF
Modular V10 (6.8l)
36
Feb 5, 2014 11:09 AM
Melmo65
17
Dec 6, 2012 01:57 PM
Country_boy_2007
16
Nov 30, 2010 12:36 AM
1bad67sbf
Apr 19, 2010 05:39 PM
