ZF t case options
Old Dec 30, 2001 | 06:48 PM
cjdm_1's Avatar
cjdm_1
ZF t case options
Hi again
Just wondering if I have any other options on a T-case for my ZF tranny it has a BW 1356 and I was wondering if a Dana 20 or 300 would bolt to it to get rid of the slip yoke and maybe help shorten the drive line. Thanks Chris
Old Jan 1, 2002 | 08:11 PM
billyb's Avatar
billyb
ZF t case options
cjdm'
if I am reading between the lines correctly, are you trying to put this in a jeep cj??
there are adapters available from advance adapters for various swaps, so check them for yours.
Old Jan 2, 2002 | 02:37 PM
cjdm_1's Avatar
cjdm_1
ZF t case options
HI
I already have this set up in my YJ but I was trying to shorten the drive train up due to a short rear driveshaft. The drive train now including the 5.0L is just about 6 feet. I have a 3 inch suspension lift now and was planning to go to a spring over but the T case (1356) has a slip yoke and no way to put a CV on it and if I wasnt able to adapt a 20 or 300 to the tranny I cannot do it uless there is a conversion for the 1356. I have a tranfercase dropped crossmember to keep the angles some what acceptable now and would prefer to raise that back up out of harms way.
Old Jan 8, 2002 | 12:21 AM
TonyG's Avatar
TonyG
ZF t case options
>Hi again
Do a search on Google.com for transfer case adapters. It will lead you to http://www.advanceadapters.com Click under "new Products" or something similar and it will take you to:http://www.advanceadapters.com/product/product.html There you will read:
Ford ZF Transfer Case Adapters
Advance Adapters has Recently developed a couple of new transfer case adapters for use with the Ford ZF 5 speed transmission. The two new adapters include Dana 300, and Atlas applications along with a Bronco Dana 20 application,
It doesn't sound like a ZF will bolt right up to the Dana 20 or 300, but the adapter doesn't look like it will add much length to the driveline. I gave you the links as there is alot of neat stuff along the way.
Your welcome,
Tony
Old Jan 13, 2002 | 01:49 PM
cjdm_1's Avatar
cjdm_1
ZF t case options
I have since changed to a 1345 with a cv style rear drive shaft thanks
Old Jan 13, 2002 | 02:00 PM
topo4u2's Avatar
topo4u2
ZF t case options
csangster
Apr 16, 2010 03:44 PM
csangster
Modular V8 (4.6L, 5.4L)
Apr 7, 2009 06:23 PM
solidrunner
Engine Swaps
Jul 22, 2006 09:25 PM
cjdm_1
Jan 27, 2002 12:30 AM
blackf350
May 31, 2001 04:33 PM
