1356 Slip yoke conversion?
Old Dec 29, 2001 | 04:09 PM
cjdm_1's Avatar
cjdm_1
Hi all
My name is Chris and new to the board .
I have a 1994 Jeep YJ and I have installed a 302 out of a 94 5.0L Mustang along with a ZF 5speed and 1356 T-Case.
My problem is that I am going to do a spring over axle conversion and my rear Drive shaft is only a foot long.I want to put a CV style shaft with a slip joint in it but my BW has a slip yoke and I was wondering if its possible to convert it to a flange or Ujoint style end?
Any help, part numbers etc would be of great help It would also be nice to be able to hook up a speedometer cable. My t-case is shifted by a lever instead of electronically if thats any help.
Thanks Chris
Old Jan 13, 2002 | 09:51 PM
TomThrall's Avatar
TomThrall
Post 1356 Slip yoke conversion?
Chris;
I'm currently going thru the same thing. I'm putting a 1345 into a shorbed pickup, and gonna have a 3 foot driveline. Here's what i've found out:
There is a flanged yolk available in the 1356 transfer cases in the late 80's to mid 90's full size broncos. I've called several salvage yards who told me that this transfer case came in some pickups too, but I can't vouch for that. If so, it was probably a shorbed single cab pickup from around 1989 to 1995. The ford parts catalog shows these pieces, but it also says the main shaft is obsolete and unavailable too, so I'm not sure that using factory parts is the way to go.
There are about 10 of these cases available in Denver salvage yards, all for around 500 dollars. Good luck.
PS: I bought a transfer case on Ebay for 300 plus shipping.
Old Jan 26, 2002 | 10:31 PM
cjdm_1's Avatar
cjdm_1
Thanks for your help.
I am going to go with a 1345 with a doble cardan joint it is about 3 inches shorter.
Chris
Old Jan 27, 2002 | 12:30 AM
TomThrall's Avatar
TomThrall
rustee90-150
1978 - 1996 Big Bronco
Mar 11, 2010 08:59 PM
cyclospot
Oct 13, 2007 01:44 PM
ZMCCALL
Nov 16, 2003 12:56 AM
cjdm_1
Jan 13, 2002 02:00 PM
