Hello to all,
I am towing my 1995 F150 with a tow bar...Do I need to have the truck idling, or is there another way to have the steering wheel free to turn without the vehicle running? The only reason I'm asking is because I have to take it a fairly long distance. Any input would be greatly appreciated.
You want to have the MOTOR TURNED OFF and the steering unlocked (disconnect the battery and turn the ignition to the "on" position) when using a towbar. Also, disconnect the rear driveshaft at the pinion and bungee chord it to something solid.
U-Haul style car dollies are not a good choice for full size trucks, they are too big, the truck's body can actually hit the fenders on the dolly in a tight turn.
The towbar will be fine for any distance provided that you leave motor turned off, steering unlocked, and the driveshaft disconnected.
if it's an auto trans i dont think that pulling the driveshaft would be a good idea since fluid will leak out...
i have heard that this isn't good for auto trans trucks since the front pump doesn't work if the engine isn't on so the transmission doesn't get any lubrication and is spinning with force from the wheels not the engine
don't know how much truth there is in that though
This is absolutely true. I'm a tow truck driver and this is why we always tow with drive wheels off the ground. If you have to tow with the drive wheels on the ground, we pull the driveshaft. Even on stick shifts, we pull the driveshaft to eliminate the risk of damage that we would have to pay for.
As for the fluid leaking out, we just pull the pinion end and chain it up to something solid underneath the truck to keep the fluid in the tranny.
