Dual Master Cylinder
Old Jun 20, 2009 | 11:32 AM
292fan's Avatar
292fan
HI all, I have tried to research this question but never could get a definitive answer. I have a 64 100 with drum brakes. I want to use a dual master cylinder. Does anyone know what will directly bolt up with little modification? It's an occasional driver, however I do make some long trips and would like some extra assurance. I understand and respect the limitations of drum brakes so a disc conversion is not an issue for me. I just want to keep braking if something ruptures..Thanks
Old Jun 20, 2009 | 05:18 PM
banjopicker66's Avatar
banjopicker66
Options with no modification - None, nic, nishto, nada.
Modifications you will need to make:
1. Find a 2-pot drum/drum master cylinder. Modify the push rod to fit the dimensions of your '64 cab. Search the posts here for the details; I think a '67 - 72 truck one will work, but you'll still need to adjust the pushrod length.
2. Add a drum/drum proportioning valve, off a '67 - '72 truck with drum/drum brakes.
3. Add brake lines between the master cylinder and the proportioning valve.
4. Add brake lines between the proportioning valve and the front brakes.
5. Add a rear brake line to the proportioning valve, and tie it in to the existing line.
6. You will need to fabricate your lines. Don't forget to double flare them.
Old Jun 20, 2009 | 05:22 PM
drof46's Avatar
drof46
Old Jun 20, 2009 | 07:47 PM
292fan's Avatar
292fan
Thanks Banjopicker And Dro46 I was just looking for that kind of info. I'm going to gather all the parts right away...
Old Jun 21, 2009 | 05:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do not use the master cylinder and/or proportioning valve off a 1967, as these parts are 1967 ONLY.
If you ever need to replace one or the other, they may be difficult to find.
Old Jun 25, 2009 | 03:47 PM
rbcyouthdude's Avatar
rbcyouthdude
I used a 69 mustang big block drum/drum and I did not have to do any modification to the rod and I did not put a proportioning valve but really really need to.
you will also have to rig up a brake light switch which is pretty easy.
Michael
Old Jun 25, 2009 | 07:06 PM
292fan's Avatar
292fan
Thanks guys for all the info. Can you believe I have overtime at work?! I'm taking advantage of that so I haven't had time to go to any junkyards yet for a prop. valve. I'll get the master cylinder(Mustang at NAPA. I'll let you know how it all works when I get every thing together. If there are any more ideas out there keep them coming.
lauxg
13
Jan 21, 2021 02:02 PM
65fordguy
33
May 3, 2016 07:41 AM
bigcrunch
Large Truck
Jan 20, 2016 11:21 AM
Resurrected 56 F100
Aug 23, 2015 07:49 AM
JefflovesF250s
Sep 2, 2004 09:22 PM
