Master cylinder upgrade
Old Jun 27, 2015 | 01:04 AM
Resurrected 56 F100's Avatar
Resurrected 56 F100
After reading the many threads on here discouraging the rebuild of the original master cylinder, I've decided to upgrade to a dual reservoir master cylinder. I want to mount it in the original location. I'll make my own bracket. I don't want disc brakes (at this time), and I'd like to keep it all manual as well. What year and make would be the best master cylinder to use? Obviously I need one that goes to a manual drum brake vehicle. Does it matter if it's a car or truck master cylinder? Do any of them have different mounting patterns (wider or narrower, narrower preferred so I can mount it next to the frame and still align with the brake rod)?
Old Jun 27, 2015 | 11:28 AM
52 Merc's Avatar
52 Merc
Your brakes are the same as found on F-100's up through the 60's and into the 70's. I would use one from a 67-72 F-100 with manual drum brakes. It should work fine.
Old Jun 27, 2015 | 12:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A common MC to use is C9AZ-2140-D, this has the 10# residual valves in the MC. This Ford # can be crossed over to your brand. It was used on 67-70 Ford pass. cars with drum brakes. Having the residual valves in the MC itself saves some bucks and real estate as far as plumbing goes. Not sure if the port sizes match the F-100 brake lines, but I think so.
Old Jul 10, 2015 | 05:58 PM
Resurrected 56 F100
Found a Dorman one on Amazon that has the OE PN in the description;
Amazon.com: Dorman M73323 New Brake Master Cylinder: Automotive Amazon.com: Dorman M73323 New Brake Master Cylinder: Automotive
Thanks for the help!!
Old Jul 10, 2015 | 07:32 PM
JPMallory's Avatar
JPMallory
To piggyback on this thread: Would this also serve as a suitable replacement for a 1948 master cylinder?
Old Aug 12, 2015 | 09:41 PM
Resurrected 56 F100
I'm no expert, but I don't see why not.
Old Aug 14, 2015 | 06:07 PM
Resurrected 56 F100
Alright, finally pulled the trigger and ordered the "recommended" master cylinder. Also picked up some 1/4" plate to make the bracket for the master cylinder.
Old Aug 18, 2015 | 06:37 PM
91Fbody's Avatar
91Fbody
Did you take any pictures of the bracket you had to make? I need to do this too.
Old Aug 18, 2015 | 11:41 PM
harleymsn's Avatar
harleymsn
It's a different mount, 2 bolt as opposed to three.
Old Aug 19, 2015 | 04:12 AM
JPMallory's Avatar
JPMallory
Thank you. I did see that, I'm looking at an adapter. After some more research, I think I know what I need now.
Old Aug 22, 2015 | 11:48 PM
Resurrected 56 F100
Sorry, no, I haven't finished it yet. It's been too hot outside lately to do any kind of metal work. I'll post pics when I do finish...whenever that happens, lol.
Old Aug 23, 2015 | 07:49 AM
pweng1's Avatar
pweng1
Is this what youre looking for
Pappys53
Aug 11, 2020 02:55 PM
Baby Blue
Nov 24, 2019 07:18 PM
Fordtruck51
1961 - 1963 F100 Unibody
Apr 29, 2012 10:46 PM
64STYLE
Jul 12, 2007 06:30 PM
DJOHAGIN
Nov 15, 2006 11:20 PM
