gear oil change?
Old Jun 19, 2009 | 11:17 PM
kupaa's Avatar
kupaa
gear oil change?
How much gear oil do i have to add if i change out the old one I just bought 4 qt of Amsoil and friction additive for 82.00 i hope that was a good price.
Old Jun 20, 2009 | 03:17 AM
Visseroth's Avatar
Visseroth
F250/F350 - Front Axle 75W90 1.8L (3.8 pints), Rear axle 75W140 Synthetic 3.3L (6.9 pints), engine oil 15 quarts or 18 quarts if you change the HPOP as well (High Pressure Oil Pump). I'll be changing my HPOP as well on the next oil change, you don't have to, I'm just a bit ****.
Transfer case Mercon ATF 1.9L (2 quarts), trans - 5spd 3.2L (3.4 Quarts) (Mercon ATF Synthetic), 6spd 5.5? (5.8 Quarts), auto 16.1L (17.1 Quarts) to 16.7L (17.7 Quarts) Mercon ATF on all
This is most of the information from the manual, not all but you get the gist.
Old Jun 20, 2009 | 06:38 AM
Izzy351's Avatar
Izzy351
Two things -- Ford changed the specs on MerconV a couple years back and put out a TSB that we can run it in our trucks now. They also put out a TSB that states to run 75W-140 in the front diff too.
I just did my diff and put the '08 rear diff cover on. Good upgrade -- have a look:
EDIT: Here's a link to where to get it. You'll need longer bolts to do it -- I went with 1 1/2" SS, but had to use an extra washer on a couple. 1 1/4" would be perfect:
http://www.trademotion.com/partlocat...layCatalogid=0
Old Jun 20, 2009 | 09:24 AM
preppypyro's Avatar
preppypyro
I didnt know we could now run 75/140 in the front diff, reps for ya Joe!
Old Jun 20, 2009 | 09:40 AM
Kwikkordead's Avatar
Kwikkordead
My Dana 135 holds 3.5 gallons.
Old Jun 20, 2009 | 10:19 AM
Izzy351's Avatar
Izzy351
OUCH!!! And I had the parts guys looking at me funny when I was asking for a gallon of it!!
Old Jun 20, 2009 | 03:31 PM
Visseroth's Avatar
Visseroth
LOL, nice! but what is TSB?
Old Jun 20, 2009 | 03:33 PM
8tsixt's Avatar
8tsixt
Technical Service Bulletin.
Old Jun 20, 2009 | 03:46 PM
Visseroth's Avatar
Visseroth
Ahh, TY
Well on my next fluid change my whole truck is going Synth. PS is starting to make noise and well I like the longevity and what Synthetic does for these trucks.
