t case swap
Old Nov 15, 2003 | 12:34 AM
ZMCCALL's Avatar
ZMCCALL
t case swap
I have a 1992 f-150 5speed (I dont think it is the mazda tranny ). I believe I have a Borg Warner 1356 (with a slip yoke). Can I swap it with a t-case that does not have a slip yoke? If so what t-case can I use and what special things do I need to watch for other than getting a new drive shaft? Thanks for any info.
Old Nov 15, 2003 | 01:05 PM
Txquadhunter24's Avatar
Txquadhunter24
the BW 1345 (i believe that # is right) is a non slip yoke T/C. Besides that there the same case and will bolt right up. If if your 5spd tranny is like the autos that year you can mount the gear driven NP205 up with just a little grinding work. with your truck being a 92 F150 with a 5spd you'll have the mazda tranny.
Old Nov 15, 2003 | 10:17 PM
ZMCCALL's Avatar
ZMCCALL
Can I rebuild the BW1356 and put a new output shaft on with a slip yoke eliminator on it?
Old Nov 16, 2003 | 12:56 AM
Txquadhunter24
I have no clue about that. You might try some searches to see what you come up with. Only time I really jack with the BW tcases is when I help friends rebuild them. I just don't trust the chain drive and oil pumps in them when ya need it. I stick with the NP205's.
Blue_Betty
15
Dec 23, 2021 05:46 PM
79str8six
Mar 26, 2012 03:35 PM
Thomsen
Apr 25, 2010 07:17 AM
cyclospot
Oct 13, 2007 01:44 PM
