worn slip yoke??
Old Feb 2, 2007 | 08:32 PM
cyclospot's Avatar
cyclospot
worn slip yoke??
I have a 96' F-150 4x4 with a mazda 5 speed and 1356 t-case with a 3" suspension lift and 3/4 ton springs. 70,000 miles since the lift. The seal at the slip yoke started leaking so i put a new one in.. twice and is still leaking the day i stuck it in. The transfer case is not over full and there is a little play at the slip yoke (going into the transfer case). Could my slip yoke be worn and if it is would I need to replace the splined shaft in the t-case? Can you get longer slip yokes? Thanks for the help.
Old Feb 2, 2007 | 08:42 PM
wrenchturner's Avatar
wrenchturner
it's possible the yoke is worn. but i think the yokes are the same. mayge a longer shaft.
Old Feb 2, 2007 | 09:08 PM
cyclospot's Avatar
cyclospot
Thanks for the reply. Do you think the t-case shaft if messed up too? Would a double c joint work with this setup?
Old Feb 2, 2007 | 11:15 PM
ncfirefighter46's Avatar
ncfirefighter46
also check the tail shaft bushing i need one myself for mine.
Old Feb 15, 2007 | 10:12 PM
cyclospot's Avatar
cyclospot
I got it fixed. It took a new slip yoke from precision bilt(KCMO), a tailshaft bushing, and a output shaft seal. Seems fine after 50 miles. I also used a little bit of ultra copper silicone to seal the tailshaft housing back up. Thanks for the help.
Old Oct 9, 2007 | 02:23 PM
cyclospot's Avatar
cyclospot
many many many more miles later.... no leaks!
Old Oct 9, 2007 | 03:14 PM
Mr. M's Avatar
Mr. M
Were you getting vibration prior to swap?
Old Oct 13, 2007 | 01:44 PM
cyclospot's Avatar
cyclospot
Not out of the ordinary that I could tell. I have to put u joint in it every thirty or fourty thousand it seems. I am running 33x 12.5s and a 4" in the front and 2" and 3/4 ton springs in the back. The mazda 5speed has some vibration in it and Im sure the t-case is loose as a goose too. There is only a couple hundred thousand on it. It probly had 180,000 or so on it before it went out. I think I might of changed the fluid in it once. Hope this helps.
ranscobia
Oct 14, 2015 07:32 PM
jereli
Jun 4, 2015 07:25 PM
sperober1
1997 - 2003 F150
Jul 1, 2014 06:47 PM
F-erOnlyRunsDwnhill
Jun 13, 2014 09:30 PM
phaethon
May 2, 2014 11:04 PM
