AC problem
Old Jun 18, 2009 | 01:51 PM
ranger714's Avatar
ranger714
AC problem
AC not working like it should on max.It fluctuates between the vents,defrost vents and the floor vents.Anyone ever had this problem on a 99 ranger?
Old Jun 18, 2009 | 03:35 PM
mfp4073's Avatar
mfp4073
I think I have seen this mentioned as a blend door issue. Do a search on the forum for "blend door" and that might get you started.
This thread is titled blend door fix, but the link is broken. Might be due to the updates today.
https://www.ford-trucks.com/forums/s...threadid=24962
Old Jun 18, 2009 | 04:54 PM
Traxxis's Avatar
Traxxis
Check under the sticky at the top of this forum. The fix should be there. I'm in the same boat with you... I'll be doing the same repair this weekend.
STan
Old Jun 19, 2009 | 09:37 AM
tomw's Avatar
tomw
Blend door is temperature -- blend hot air and conditioned air to get the temp you like.
You have a vacuum leak or a funky check valve in the vacuum reservoir.
Try setting the controls to 'panel', blower on, and then accelerate rapidly. If the air flows out the defrost, it is a vacuum problem, as the manifold vacuum will drop with the throttle opened wide.
tom
Dude-Ford
34
Jan 10, 2023 12:08 PM
chiefjefe
75
Jun 13, 2017 09:02 AM
fletchb
Aug 25, 2016 10:01 AM
RMeans
Apr 21, 2016 08:36 PM
NorthEastTexasHog
Jan 5, 2016 09:41 PM
