2003 Explorer a/c problem.
Old Apr 21, 2016 | 05:50 PM
RMeans's Avatar
RMeans
4.0 v6 A/c works great at first. Then after a while stops blowing out the center dash vents. Any idea on what to check? Still blows cold out the vents by each front door
Old Apr 21, 2016 | 08:19 PM
steve(ill)'s Avatar
steve(ill)
air direction is controlled by 3-4 vacuum operated doors/ dampers inside the air duct. You have a problem with one of the doors or the controlling vacuum cylinder ....
look at 4th post down... look at door 2 and 18... check if you also have air a defrost when you loose the vent but have door vents working.
https://www.ford-trucks.com/forums/9...-please-2.html
Old Apr 21, 2016 | 08:36 PM
RMeans's Avatar
RMeans
Thank you Steve
Varro
Oct 10, 2016 06:21 PM
mkoppler123
Jun 30, 2014 05:21 PM
shakebaker69
1997 - 2003 F150
Sep 3, 2013 06:13 PM
drivembig
Jan 9, 2010 04:25 AM
pegt10
Oct 15, 2006 09:48 AM
