Front hub dilema
Front hub dilema
I'm in the process of replacing the auto hubs for manual, in my '92 F150. The left hub was blown apart when I got the truck, and I figured that would prove to be the most arduous, but n-o-o-o-o..... It's the right side that's giving me fits
The retaining ring that has to be squeezed to remove the hub body is frozen in place, and one of the legs has actually broken off. Has anyone had a similar situation, and how did you overcome it? Does anyone think I would ruin the main hub if I heated the area where the retaining ring sits, to break the corrosion bond, then try to physically pull the ring out through the square hole from one side? I'm running out of ideas here....
Thanks...
Lee
Thanks...
Lee
i think what he is saying is the ring that goes around the hub that you hav to use needle nose to compress both sides is broke on one side. so he needs to know how to get the ring out so the hub will come out.
Is it the bigger ring just inside the hub? I like to use two ice picks to get a hold of mine and get it out. Two small screw drivers would work also. Just get it to move inside and then get behind it to work it out.
You gents are on the right page, it is indeed the big ring that has to be squeezed to remove the splined hub body. That ring is "frozen" in place so that it can't be squeezed/compressed to remove the hub body, and one of those fingers that you use the needle nosed pliers on, broke off during the first squeezing attempt.THAT'S the dilema!!
Lee
Lee
OK, the problem is solved. Had to destroy the hub and replace it with a used piece from the local boneyard. Here's some pic's of what the problem was;
There must have been water in the hub when the truck was parked in '05, 'cause everything "froze". First pic is of the retaining ring and the part of the hub I cut off.
Then, I had to drive out the auto hub. It looked like this.
This is a shot of the hub body, showing the rusty interior.
This turned out to be a blessing in disguise, because whomever did the last bearing repack, didn't know how to do it. The outer locknut was less than finger tight, the spacer ring wasn't on the peg of the inner locknut, and the outer wheel bearing was full of metal shards from being run without grease
Putting in the new manual hubs was a snap
Later...
Lee
Later...
Lee
i just upgraded my hubs on my flareside from the auto's to the manual... i got the warn premium locking hubs which was about $125 for the set....when i did mine though i had to get the "spindle conversion kit" which was essentially a different nut to hold everything in..... i believe that was an extra 30 bucks.....
WatsonR
Sep 8, 2014 08:22 PM
PRIMERED79 SHORT BED
18
May 13, 2012 10:59 AM
meb9796
Feb 20, 2012 02:38 PM
abovetec
Jul 29, 2010 09:04 AM
