Ss hpx
Old Jun 16, 2009 | 02:52 PM
gasgrunt88's Avatar
gasgrunt88
Ss hpx
Hey guys, just got my SS HPX line today. Only one problem...
How do you install it?
Old Jun 16, 2009 | 03:03 PM
zx250's Avatar
zx250
Of the next Riffraff East
Pull the two middle oil plugs out and put the ends of the line there.
Old Jun 16, 2009 | 03:08 PM
zx250's Avatar
zx250
Maybe this will help.
Old Jun 16, 2009 | 03:10 PM
gasgrunt88's Avatar
gasgrunt88
Ok, so I found it. I don't have to remove the spider do I?
Old Jun 16, 2009 | 03:12 PM
zx250's Avatar
zx250
Nope, but it will make it much easier if you do. Plus, it would be a good chance to check your boots out.
Old Jun 16, 2009 | 03:23 PM
big poppa's Avatar
big poppa
I did mine with the spider on but Barry's right, does make it easier. Just a tip, when you unscrew the plugs, have your HPX bolts ready to go in, then your line, oil seeps out slowly then you have't to deal with oily hands. Snug tighten, don't overtighten..
Old Jun 16, 2009 | 03:35 PM
gasgrunt88's Avatar
gasgrunt88
Hmm... Maybe I'll have a look see in the morning. Don't know how comfortable I am with taking the spider and whatnot off by myself.
Izzy351's Avatar
Izzy351
Be warned -- I was paranoid about over-tightening, but ended up with them too lose. Had to replace the O-ring on one side as the 2500+ psi of oil shooting past it tore it up.
Old Jun 16, 2009 | 03:42 PM
zx250's Avatar
zx250
If you don't remove the spider, it's tough to overtighten them at least with my old hands.
Old Jun 16, 2009 | 03:51 PM
Izzy351's Avatar
Izzy351
True. But a set of line wrenches helps.
Old Jun 16, 2009 | 03:56 PM
big poppa's Avatar
big poppa
That what I used. I,m one for tightening things too much so take that with a grain of salt, snug them down good but be careful..
Old Jun 16, 2009 | 04:03 PM
zx250's Avatar
zx250
That will be the easy part. Just loosen and slip/slide and some pulling may be needed.
Old Jun 16, 2009 | 04:51 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give me a call and I will walk you through it. It takes about 15 minutes to install and you really don't need to remove anything unless you really want.
Old Jun 16, 2009 | 04:55 PM
zx250's Avatar
zx250
Clay's right, you don't need to remove anything, but for me, it makes it easier to recover lost parts and tools, which reminds me, if you do pull the spider, cover the intake openings with a rag so stuff don't get it there. I've done it both ways, one for me and one for my buddy. We pulled his spider because he needed new boots anyway. It was a lot easier without it in the way.
