C6 fluid capacity
Old Feb 13, 2002 | 04:03 PM
jalopy45's Avatar
jalopy45
C6 fluid capacity
What is the fluid capacity of the C6 used in a 1972 M500 chassis?
Old Feb 14, 2002 | 10:15 PM
Like M. Fords's Avatar
Like M. Fords
C6 fluid capacity
How tall is your C6's oil pan. The std. pan that is about 1 - 1 1/2 inches tall will allow about 13 quarts if the torque converter is drained. If you have a deep-sump pan, auxilary coolers, an external filter, etc. expect more capacity. Your best bet would be to add about 8 quarts; start the engine; check, add, go through all the gears, check, add, test drive a few miles, check and add as necessary.
Expect to burn-up a full case+. The last time I changed the oil, I purchased ATF by a 5 gallon pail and used a hand pump. The money I saved in buying a pail over individual quarts paid for the pump.
Old Feb 15, 2002 | 12:17 AM
the law's Avatar
the law
C6 fluid capacity
Tonyg1723
May 18, 2017 06:03 PM
Blue and White
Oct 23, 2016 08:09 PM
c96drumm
Aug 13, 2016 08:21 AM
EpicCowlick
Aug 12, 2016 09:07 PM
jperlette
Apr 2, 2009 01:21 PM
