power window problem maybe??
Old Jun 15, 2009 | 01:38 PM
PsD007.3's Avatar
PsD007.3
ok soo i noticed lately my windows are starting to go down slower than normal more soo on the driver side, the windows are working it just seems there working slower than normal, and it also seems that they work faster and better the hotter it is outside...any idea's??
Old Jun 15, 2009 | 01:47 PM
patrick77598's Avatar
patrick77598
I have heard of people putting a special lubricant on the weather stripping to help the windows work faster, it sounds like your weather stripping is sticking to the window.
Old Jun 15, 2009 | 01:48 PM
nutfarmii's Avatar
nutfarmii
I recall Dan (Kwik) put something up about taking out the glass and applying soap? to the frame rails and that should help out, use a bar of soap like you would furniture drawers to slick them up and assist the up and down.
Will try and dig up the post it helped my passenger door window, someone else may chime in soon.
Old Jun 15, 2009 | 01:52 PM
PsD007.3's Avatar
PsD007.3
what would you recomend puttin on the window sills?? to make it slid easier??
Old Jun 15, 2009 | 02:20 PM
66f25red's Avatar
66f25red
see if you can find a dry Silicone lubricant.
Old Jun 15, 2009 | 02:39 PM
PsD007.3's Avatar
PsD007.3
like that silicon thats in the spray can???
Old Jun 15, 2009 | 02:43 PM
66f25red's Avatar
66f25red
Silicone
Yes, Spray can, the dry type is less messy if you can find it.
Old Jun 15, 2009 | 02:51 PM
PsD007.3's Avatar
PsD007.3
anything else that would work?? and just apply it to the rubber sills??
Old Jun 15, 2009 | 03:09 PM
66f25red's Avatar
66f25red
Actually it works much better when you apply it to the window runs, the sills will spread whatever you use along the entire window area. Most resitence is in the runs.
brandon.edwards
Mar 24, 2014 01:47 PM
BroncoRN
Nov 5, 2012 10:39 AM
PsD007.3
15
Sep 25, 2009 08:47 PM
PsD007.3
Apr 26, 2009 12:18 PM
truckmonger1
Jul 2, 2006 09:24 PM
