Window motor rebuild?
Old Nov 4, 2012 | 07:05 PM
BroncoRN's Avatar
BroncoRN
My drivers window gets progressively slower the further down it goes. Does this seem like motor is shot? Can you open window motor case and rebuild it like the older ford window motors?
Old Nov 4, 2012 | 10:51 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Bronco, mine did that when I bought it. It was just binding from a lack of lubricant on the gears/rails inside the door. I pulled the door trim off the inside of the door (driver's), and I sprayed the rails and moving parts with a silicone lube while rolling it up and down, after 10 times, it would go all the way down again. After two days it worked perfectly. Just took time for the lube to work itself into all the nooks and crannies.
On a side note, it wasn't much fun cleaning the silicone lube off the glass over the next week...
Old Nov 5, 2012 | 08:18 AM
BigPigDaddy's Avatar
BigPigDaddy
I had the same issue. The motor was fine, it was just fighting friction and the friction was winning.
I just used silicone spray (the clear type not the greasy type) to drench the felt channels. It has been fine for 2 years now.
Old Nov 5, 2012 | 08:57 AM
BroncoRN's Avatar
BroncoRN
Awesome! Good to know
Old Nov 5, 2012 | 10:39 AM
labman1014's Avatar
labman1014
I guess I need to try that also. Mine though gets slower the colder it gets.
Sw1tchfoot
Oct 1, 2011 07:40 PM
01X7.3psd
Jun 20, 2011 07:02 PM
leesurfer
Sep 26, 2007 07:56 PM
Josh88Ford
Sep 30, 2006 10:59 PM
