Sponsored by: Real Truck
'99 Power window/relay question
Old Jun 27, 2006 | 09:16 PM
truckmonger1's Avatar
truckmonger1
After my last post I took the suggestions to pull the door panel and lube the window tracks. I did that and ran the window up and down about 5 or 6 times with each trip up, the window got progressively slower. About half way up the 6th time, it really slowed and finally stop. The switch would do nothing. I let it set about 10-15 seconds, hit the up switch, the window went up all the way but slowly. The whole time, I noticed that it seemed the relay was clicking kind of loud. Is this normal? Does it sound like the motor? I priced one at Autozone $54 and NAPA for about $100 with the NAPA motor having a 1 yr. warranty. Thoughts or suggestions welcome. Thanks.
Old Jun 28, 2006 | 03:19 PM
high ho silver's Avatar
high ho silver
Try swapping the relay from another door and if it does the same thing you haven't spent a penny just a little of your time to satisfy your curiosity. It beats buying something electrical that you can't take back once it has been installed.
Old Jun 29, 2006 | 12:24 AM
7.3 Ex's Avatar
7.3 Ex
I'll be interested to hear your solution. My front passenger side window has always been slow & has stopped many times. I have to make sure the idle is up & things are charged before i do it up or down. When i hold all 4 buttons to put all of the windows up or down simultaneously, it is the only one that takes longer. Sometimes, the rear vent windows won't move & i have to wait a while for them as well.
Old Jul 2, 2006 | 09:24 PM
truckmonger1
I swapped the horn relay to the one touch relay and it didn't make a difference in how loud the click was or the fact that the window still worked 5 or 6 cycles and then slowed way down and finally stopped. I guess that it looks like the motor.
Methodical_1
18
Jun 12, 2018 08:50 AM
H20ENG
19
Feb 21, 2013 09:21 PM
BigBlue99
Apr 23, 2012 03:05 PM
jdguest
Jan 19, 2011 05:39 PM
rjeremyj
1983 - 2012 Ranger & B-Series
Nov 22, 2010 08:43 AM
