Short and sweet. 1980 F250 Ranger w/ a C6 auto. 400M engine that I think just spun a bearing?
Low end knock and it will barely run. Question is, local Craig’s list guy has a 351C for sale would this be a simple engine swap?
<o></o>
Thanks
need to change the trans,as the cleveland uses the windsor bell housing.351 m will be a straight swap.the modified series engine uses the same bell housing as the 429/460.
