I'm new please answer!! =)
Old Jun 14, 2009 | 01:06 PM
Shroomy06F150's Avatar
Shroomy06F150
Exclamation I'm new please answer!! =)
I personly do not own a ford truck but my father does. I want to start buying performance parts for my father's truck as gifts.
The firts part i was looking at was a helix throttle body spacer for the 06 4.6L V8 F-150. The site says "up to 22 hp gains" but i know not to trust what ads say so i was wondering if anybody had this item on this truck or could give me a educated guestimate on the hp/tq gains from this piece, im not looking for anything crazy just somthing youll be able to feel alittle and maybe give some extra power and throttle response.
Thank you for your time
Dustin
Old Jun 14, 2009 | 01:18 PM
ggwash21's Avatar
ggwash21
I wouldn't waste your time on Throttle spacers. I personally would go with a CAI "cold air intake" by volant there are others but that is the most common i see.
Old Jun 14, 2009 | 01:20 PM
NASSTY's Avatar
NASSTY
Save your $$ for a programmer.I doubt you would see any gains from a tb spacer.
Old Jun 14, 2009 | 01:22 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Throttle Body spacer = Paper weight
They work in Carbuerated motors. That is because the of the added height they put the Carb above the intake ports. Basically a cheap alternative to a good High Rise Intake...gives the air/fuel more time to mix prior to entry
In EFI motors...pure crap. Just add some noise. Especially in setups like Ford with Direct"ish" injection. The injectors are about 1" from the intake valves. So the "High Rise" affect is worthless
Old Jun 14, 2009 | 01:23 PM
FTE Trigger's Avatar
FTE Trigger
ggwash has it...
a TB spacer won't usually give fruitful results by itself. Usually when people have any real gains with a TB spacer, they have a CAI, tuner and some other add-ons to asst.
Ryan50hrl's Avatar
Ryan50hrl
yep....save your money
Old Jun 14, 2009 | 01:26 PM
Shroomy06F150
What about this?
what about an AFE cold air intake does that sound better?
Old Jun 14, 2009 | 01:36 PM
NASSTY's Avatar
NASSTY
Better than a (useless) tb spacer but nowheres near as good as a programmer
Old Jun 14, 2009 | 05:42 PM
4playin's Avatar
4playin
I have a Power Aid Throttle body spacer, the edge evo, and a Airaid intake. The TB spacer was the last one i put on and all i noticed was 1.5 to 2 mpg gain and a whistle noise. I like the increase in mpg i'll take all i can get.
shissqbob
2004 - 2008 F150
31
May 15, 2006 03:45 PM
sbeII
1997 - 2003 F150
Mar 30, 2005 10:56 PM
valdezvip
Exhaust Systems
Mar 24, 2005 04:30 PM
CPerry
Modular V8 (4.6L, 5.4L)
18
Oct 2, 2003 08:22 PM
