Starter sticking on
Old Jun 13, 2009 | 09:18 PM
Sgt_Pepper17's Avatar
Sgt_Pepper17
Starter sticking on
Hey,
My buddy just bought a house that came with an old 79 F350, dually, dump bed. He's in the process of fixing it up to haul scrap and remodeling crap off the property.
We're having a problem with it. First off, I replaced the ignition module and fuel pump with newer ones I had laying around. We replaced the ignition switch with a brand new one as well.
The truck will fire and run, however, the starter sticks on until you pull the red trigger wire off the solenoid. Once the wire has been removed you can replace it and the starter stays disengaged.
What could be the problem here? I'm all out of ideas... Thanks.
Erik
Old Jun 14, 2009 | 09:23 AM
porky2118's Avatar
porky2118
Hi sounds to me like the solinoid is sticking. Try a new one. It should only be around $10 bucks
Old Jun 14, 2009 | 10:53 AM
Sgt_Pepper17
I put a newish one on that I had laying around. I think I used it on one of my trucks for a few months. Problem still remains...
Old Jun 14, 2009 | 11:37 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You have some wires crossed then.
What do you mean "RED" trigger wire? A PO might have rigged up something that isn't factory then.
Josh
Old Jun 14, 2009 | 12:27 PM
Sgt_Pepper17
It's a red wire with some tracer on it. Can't remember the color. Here's the kicker.
I can manually disengage the solenoid by removing the trigger wire, however, if I replace the trigger wire right away, the solenoid does not re-engage. Some circuit, I'm guessing, is being disengaged once the trigger is removed, and is not re-engaged until the key is recycled back to the "start" position.
I don't have a wiring diagram, so I'm having a hard time tracing all the wires.
Old Jun 14, 2009 | 01:22 PM
fmc400's Avatar
fmc400
MSEE
Let's get some more information. The next time it sticks, remove the wire on the 'S' post. According to you, this is when the solenoid disengages. Immediately measure the voltage on the wire boot you removed. A test light will suffice as well.
One of my favorite things about working on trucks is that there is a logical explanation for everything, no matter how wild a problem seems at first.
AtlM5
Dec 13, 2015 07:57 PM
GLOBALSDF
16
Jun 3, 2015 01:37 PM
bullnose lover
Dec 11, 2014 11:45 AM
Alabama1988
18
Sep 5, 2014 06:06 PM
chopped&dropped
Apr 24, 2009 08:26 AM
