Are they the same?
Old Feb 25, 2002 | 08:58 AM
thewall's Avatar
thewall
Are they the same?
Howdy all,
I need to replace the 3rd member of my '72 9". I have the opportunity to pick up a complete rear end from a '65 T-bird. Aside from the gear ratio, is everything else the same? I.e. differential housing. I'm not concerned about the axle housing as I'll be using the one from my truck, but the fellow I can get the rear end from is questioning whether or not the truck rear end is 'beefier'.
Any help is much appreciated.
Thanks,
Don
Old Feb 25, 2002 | 10:41 AM
FortyFords's Avatar
FortyFords
Are they the same?
I believe the difference is in axle splines some 28 some have 31.
and bearing size.can you get the tag info of both rears and post it
we can decifer it for you.
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Feb 25, 2002 | 11:32 AM
thewall's Avatar
thewall
Are they the same?
Thanks Rich, if that's the only difference then I'm ok with the swap, I really only need the diff housing all my other bits are ok.
Thanks again for the help.
Don
Old Feb 25, 2002 | 12:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are they the same?
Tectron1
Dec 18, 2014 08:45 PM
greyghostdriver
Dec 9, 2014 10:22 AM
ChuckRob
18
Jun 2, 2012 10:59 AM
colortec
15
Apr 26, 2009 06:04 PM
cowmilker
Dec 30, 2007 12:36 AM
