Ahh, ok, well there's a blue, black and grey CPS. The blue is from international, well the grey is too but the blue is different from the others. Some have reported good thing, some not. That's why I asked. I thought I'd check to see if anyone has used one and what their thoughts were on it.
Also, the check light, SES, and brake all come on at the same time and shut off at the same time as if the moter shut off and turned right back on again. I checked for any additional codes and there was nothing new, nothing I don't know about already.
Visseroth- I have 2 used black CPS's, if you want to swap one in and see if it helps its all yours. I might be able to head your way this week one evening if needed. I'm voting loose connection or rubbed wire someplace, and the smack of the e-brake releasing is causing it to act up.
Hey, sounds good to me. I greatly appreciate it and if you want to take a look that'd be fine. I checked the back of the PCM and it was still nice and night.
Just give me a buzz when you're in town.
