New Wheels...
Old Jun 10, 2009 | 09:21 PM
Traxxis's Avatar
Traxxis
New Wheels...
Just in case any of you are curious what Mustang wheels would look like on a Ranger... here you go.
They came from a 2007 Mustang (v-6 I think). The only modification I had to do to them was gring out the hub hole a little. Unfortionately though, I am not able to put the front spinners (hub caps) on because of the front hub.
Anyway, I was just curious to see what you all thought.
STan
BTW: The wheels and tires together... $150. Not bad, eh?
Old Jun 10, 2009 | 09:24 PM
g_k50's Avatar
g_k50
I can't get tires for my Ranger for 150. That's a good price.
Old Jun 10, 2009 | 09:27 PM
sfcwoodret's Avatar
sfcwoodret
Looks pretty good.
Old Jun 10, 2009 | 10:02 PM
katoranger's Avatar
katoranger
They look really nice on your truck. Bargain price too.
I just need a trim ring and a center cap for my truck on the stock steel wheels. I got new tires so they will be staying for awhile.
Allen
Old Jun 12, 2009 | 10:57 AM
Rockledge's Avatar
Rockledge
I like the look.
Old Jun 14, 2009 | 02:06 AM
sfcwoodret's Avatar
sfcwoodret
Nothing looks bad coming off of a recent Mustang.
Old Jun 14, 2009 | 07:41 PM
El_Jefe's Avatar
El_Jefe
Looks good. I have seen Cobra rims on that gen too they look tight as well...
Old Jun 16, 2009 | 08:44 PM
Traxxis's Avatar
Traxxis
Here is a better shot. Along with my freshly painted hood.
Not bad for 114k, eh?
Does anybody know of a way to tame the brake dust on the front wheels? I am pretty disappointed with the brake pads I put on my truck about 6 months ago. They put out WAY too much dust. I can clean the wheels, then have a noticable dusting in about 1-2 days... and I drive very lightly (no hard braking).
Old Jun 17, 2009 | 05:14 AM
Monsta's Avatar
Monsta
Sit. Stay.
You can use a product called Kleen Wheels (google).
However, brake dust causes other issues. Namely; brake "warp". Now warping is a myth but too much dust from the pads can create an issue call cementite deposits. This is caused when you brake and keep you foot on the brake after a prolonged or hard stop which careates an abundance of heat. Basically, it "melts" (not exacty but...) brake pad material to the hot rotor and causes warped rotor sensation when you brake.
Only way to fix the problem would be to resurface or replace the rotor.
Switching to a harder compound brake material can help eliminate that. Ceramics are good for low dust performance but can take a while to get up to good operating temp.
There are a lot of pads out there now that are labeled "low dust". Look into those but get some more recommendations from others on the board here.
I like Hawk pads, personally. Cryo'd pads and rotors also help.
mustang Stan
Jun 27, 2013 07:33 AM
versitek
6.4L Power Stroke Diesel
Dec 15, 2010 11:19 PM
Traxxis
Oklahoma Chapter
23
Feb 21, 2006 12:22 PM
Stanstruck
Mar 29, 2004 03:49 PM
Stanstruck
Bronco II
Jul 9, 2003 03:56 PM
