Sponsored by: Auxito
5.4 ticking
Old Jun 10, 2009 | 07:23 PM
trugertha's Avatar
trugertha
5.4 ticking
hey everyone my dads truck has the good old 5.4 ticking noise..what is this exactly and how do i rid his truck of it for good? its a 2001 5.4 f150 kr..thanx
Old Jun 11, 2009 | 12:24 AM
papajoemrt's Avatar
papajoemrt
there are many things on the 5.4's that can cause ticking.
the injectors on these trucks will tick. (No repair that I know of)
a manifold leak can cause a ticking sound due to a leak. the studs rust out and cause a leak. (check and repair the studs, replace the gasket while it's off, if it persists get the manifold planed as it may be warped).
a sparkplug about to be blown out can cause a ticking sound. (wait for it and repair because the threads are already weakened, to repair after insert a helicoil or get a professional kit which is stronger.)
lash adjusters. (someone told me that they start to tick when they get loose but it's not a big deal. replace if it becomes a real pita.)
sticky valve (try seafoam to be cheap)
piston slap (heard someone mention this before, still not sure of what this actually is, someone may elaborate on the subject)
this is where i would start seeing that my truck also ticks and i've posted a thread about it and i've looked into it quite a bit but other people on here may have other suggestions but this is what i came up with when i started looking into the mysterious ticks from the bellows of the 5.4.
Old Jun 11, 2009 | 12:47 AM
trugertha's Avatar
trugertha
trucks in great mechanical condition just replaced passanger side exhaust mani, plugs are good, definatly not piston slap, i dunno bout a sticky valve think that would make it run rough?
Old Jun 11, 2009 | 09:49 AM
westflgator's Avatar
westflgator
If it's coming from the motor, and it is worse when you first crank it up, and then quiets of some after that, it is probably lifters tapping. I have two f150's, and they both do the same thing. My 97 started around 35K, and it now has over 280k and the motor has never been gone into, just the normal maintenance. It won't hurt anything, it's just annoying. If you run fully synthetic oil it will help.
Old Jun 11, 2009 | 10:05 AM
papajoemrt's Avatar
papajoemrt
not sticky valve sorry sticky lifter.
a lot of these trucks have a ticking sound that doesn't affect it's performance or damages the motor it's just a nuisance, let's you know it's still there.
Old Jun 11, 2009 | 10:39 AM
SnowHiker's Avatar
SnowHiker
my 99 5.4 was ticking at 20k. they said it was a "bent rod" had to get a whole new engine, a rebuilt which i think is a much better then the orig one. thing is it cost me 800 bucks to rent a truck for a week and ford never repaid me.
Old Jun 11, 2009 | 02:18 PM
trugertha's Avatar
trugertha
thanx guys i thought it was just something annoying old man wasn't sure tho thanx again
Old Jun 12, 2009 | 12:04 AM
papajoemrt's Avatar
papajoemrt
obviously if the tick gets worse then it would be something to get checked out before it does become more serious and therefore costing more than a nuisance to the ear.
Old Jun 12, 2009 | 02:29 AM
trugertha's Avatar
trugertha
no im sure its nothing same tick my buddies dads has.. had it since new he tells me and stil has it 373,000kms later
Old Jun 12, 2009 | 05:29 AM
shorebird's Avatar
shorebird
I hope that it doesn't sound like this guys motor; http://consumerist.com/5052258/fords...-pinging-noise
Old Jun 12, 2009 | 01:24 PM
bc11's Avatar
bc11
Mine has a ticking sound at startup from the right rear of the engine when cold. After it warms up in a few blocks it quits when the engine and manifold expand and seal the exhaust leak. Ford guys say it is a common problem for the right rear nuts on the exhaust manifold to come loose or the studs break off. They won't know which till they can pull the wheel well and look. Maybe a stud broke or you have a loose nut cause they didn't torque down your new manifold. Course a broken stud requires manifold removal. Probably a manufacturing defect in the head or manifold.
If I could figure out how to get the wheel well off, I'd fix it myself. I'll wait for a response here before I post a new thread.
Old Jun 12, 2009 | 03:34 PM
papajoemrt's Avatar
papajoemrt
good read right there.
did they ever get down to what was causing the pinging sound? was it a bad lifter?
Old Jun 15, 2009 | 03:28 AM
trugertha's Avatar
trugertha
im glad i don't have a story like that to tell
Old Jun 15, 2009 | 02:46 PM
Volkmann's Avatar
Volkmann
i just recently got rid of my ticking noise. Put some marvels mystery oil in the oil and some in the gas tank. Frees up sticky valves and lifters. I put it in and less than a week my ticking was gone!
Hoosiergirl
2004 - 2008 F150
Feb 28, 2017 10:09 PM
housba2007
Modular V8 (4.6L, 5.4L)
Feb 10, 2017 06:59 PM
Ziob
Nov 16, 2015 09:08 AM
Superdutystiller
May 7, 2015 01:51 PM
ncred02
6.2L V8
Feb 19, 2015 04:20 PM
