snapped off radiator drain plug
Old Jun 10, 2009 | 06:10 PM
billj6's Avatar
billj6
'99 Ranger, 3.0 ltr., 107,000 mi.
Tried to drain radiator and the plastic plug snapped right off. No leakage since it never opened but I won't try to fix it.. Guess I'll have to disconnect the lower hose to drain the radiator now. That 10 year old piece of hose has never been off so I think it best to buy a new section and two hose clamps so I don't start a leak and lose the new gallon of anti freeze and then have to replace it anyway. Anyone had this happen on an old truck?
Old Jun 10, 2009 | 06:36 PM
Rockledge's Avatar
Rockledge
You can find replacement drain plugs at many auto parts stores.
Old Jun 10, 2009 | 06:40 PM
1949f1's Avatar
1949f1
my 86 snapped like that. i took it out and used a pair of needle nose pliers and got the rest out. like rock said, advance auto had mine.
Old Jun 10, 2009 | 06:51 PM
billj6's Avatar
billj6
On my '99 the plug is locked in. It never came all the way out. It just loosened enough to allow the coolant to flow out. I think it was Ford's way to make sure you didn't lose the plug.
Old Jun 10, 2009 | 07:25 PM
g_k50's Avatar
g_k50
Old style drain *****, really old, like 60's old, would screw-in to drain. So the draincock would be turned clockwise on these old style.
Now they unscrew like they should, counter-clockwise.
Old Jun 10, 2009 | 08:38 PM
billj6's Avatar
billj6
drain plug
Can you get some radiator hose and trim it with scissors to replace the lower hose or do you have to buy the exact piece by part number?
Old Jun 10, 2009 | 08:43 PM
katoranger's Avatar
katoranger
I don't think the replacement hose is all that expensive. Would be much easier to buy the one that has the correct bends and install it.
Allen
Old Jun 10, 2009 | 09:02 PM
Traxxis's Avatar
Traxxis
I agree with Kato, it is much easier to buy the actual part. I don't think mine for my 96 3.0 was any more than $15.
Old Jun 11, 2009 | 10:05 AM
Bear River's Avatar
Bear River
Former ******
Besides, many lower radiator hoses need internal reinforcement since they are the suction side. Otherwise the hose can collapse and you get no coolant flow. A direct fit hose will have the reinforcement, or at least it should
Old Oct 27, 2011 | 06:28 AM
kullamon's Avatar
kullamon
Anybody know if true for a 2000 ranger?
Lowedogg
37
Sep 14, 2024 12:46 PM
AMG-SM
29
Sep 9, 2019 11:47 AM
Built-Ford-Tough91
1978 - 1996 Big Bronco
Mar 7, 2015 09:15 PM
Meatball98
Mar 3, 2015 06:54 PM
