coolant drains in block
Old Mar 3, 2015 | 06:32 AM
Meatball98's Avatar
Meatball98
Has anyone ever had trouble breaking loose the coolant drains in the block? I am going to do a flush with new hoses and a new radiator install. Just wanted some input so I don't get any surprises trying to get them out. Any tips or tricks? Would having a warm not hot engine help any?
Old Mar 3, 2015 | 10:36 AM
jayro88's Avatar
jayro88
I did not have any trouble with mine. I have read that having a warm engine can help.
Many recommend you install drain ***** in place of the plugs so you don't have to take a coolant shower the next time you do it.
Old Mar 3, 2015 | 03:16 PM
whiteboyslo's Avatar
whiteboyslo
IIRC, they're brass, so you need to take a bit of caution. Use a 6-pt socket if you can to avoid stripping. They're also a bit of a hassle to get at, but nothing a good u-joint and some extensions can't handle.
Mike
Old Mar 3, 2015 | 03:25 PM
madpogue's Avatar
madpogue
One or both may have a 1/4" square hole drive rather than a hex head. Passenger side is harder to reach; you MIGHT opt to remove the starter.
If they're hex head, a six-point socket will avoid ROUNDING the heads. To avoid stripping the THREADS, use a liquid or paste thread sealant (DON'T use thread tape).
Old Mar 3, 2015 | 03:56 PM
Coutu's Avatar
Coutu
On the 7.3 Powerstroke, they're square. We had to take the starter off to get the passengers side. It was also was stripped a bit, so we "pointed" the end of the tool used to get it out (can't think of the name right now) so it tapered down a bit, then tapped it into the drain so it lodged itself in there to avoid stripping it a bit more. We just put a new one on after that.
Old Mar 3, 2015 | 05:04 PM
whiteboyslo
Crap. Fingers working slower than my brain. Yes, use a 6-pt to keep from ROUNDING it, not stripping it.
I was able to remove both of mine without taking out the starter or anything else. I do recall the starter got one heck of a bath, though.
Mike
Old Mar 3, 2015 | 06:54 PM
Meatball98's Avatar
Meatball98
Thanks guys
sandsOtime
26
Apr 16, 2019 06:19 AM
norm805
Jun 3, 2009 10:16 PM
gixxer1000
May 3, 2007 09:32 AM
nitrobologna
Jul 17, 2003 11:04 AM
cyberdr2
1978 - 1996 Big Bronco
Feb 2, 2003 08:24 PM
