C-4 throttle cable?
Old Mar 17, 2002 | 11:02 PM
cbwarrior's Avatar
cbwarrior
Post C-4 throttle cable?
I'm putting a V8 in my Ranger, and the C-4 came with a rod to hook up to the carb for the kick-down. Is there a way to put a cable set-up on it instead of that rod? I need as much space as possible, and I feel that solid piece would just get into the way. Thanks!
Old Mar 18, 2002 | 01:05 AM
f150sleeper's Avatar
f150sleeper
C-4 throttle cable?
I believe Lokar makes a cable to replace the rod check in jegs or summit.
1979 F150 Custom 2wd C4 302 painted ford blue, bored .040 over, flat top pistons with valve reliefs, Edelbrock Performer cam, carb, and intake, stock heads til next spring, MSD Ready-To-Run distributor, MSD Blaster 2 coil, Edelbrock air cleaner and valve covers, Dynomax headers, dual exhaust with Flowmaster 40 Series mufflers, 38 gallon fuel tank(how i can drive it further than around the block) 9" rear end with 2.75 gears and open diff to change to 3.50s and locker next spring.
"Your only as fast as me until the light turns green"
Old Mar 18, 2002 | 08:07 AM
winfordr's Avatar
winfordr
C-4 throttle cable?
I used a Lokar cable on my 54 F100 with Mustang 5.0 HO EFI and C4. It was a "snap". Although it was madke for a carburetor model, it was a simple mod to make it work on my throttle body.
Winford
Old Mar 18, 2002 | 08:59 AM
winfordr's Avatar
winfordr
C-4 throttle cable?
fox3698
Jul 2, 2011 06:16 PM
newblder
Sep 11, 2009 10:16 AM
FrankienFord
Jul 9, 2009 08:14 PM
N7ghtwolf
Sep 14, 2007 10:21 AM
jscott2124
Feb 9, 2005 09:31 AM
