theres a factory sticker under the hood that says the truck has it. I've never heard of it, but it obviously does since there is a rev limiter that cuts out a couple cylinders. just curious where they put it
If it has the soft touch rev limiter then it must have a box ..It shouldn't be to hard to find ,Its bright red..It should hook to the battary directly , mabee follow the wires . Lew
This is true the sticker dosn't mean any thing... What RPM are you hitting the limiter ?? If it has the soft touch ,the factory limiter would need to be disabled ..Lew
I can't tell you for sure what rpm the limiter kicks in, but it must be about 5,000. maybe someone did pull it off the truck because its nowhere to be found
