Transmission Fluid
Old Mar 31, 2002 | 08:08 PM
scionti 94's Avatar
scionti 94
Transmission Fluid
What is the difference between Mercon and Mercon V transmission fluid?The fluid level dipstick on my '94 calls for Mercon, but I have been told that I could use Mercon V. Newer Ford products use Mercon V, but should not use Mercon. Need a little information on this.
Tampa Bay'94 EB,5.8,towing package, Rancho RSX7000 shocks,Westin nerf bar, Energy Suspension poly, keeping it basically stock
Old Mar 31, 2002 | 09:30 PM
charlez's Avatar
charlez
Transmission Fluid
Mercon V is a synthetic blend fluid. It is ok to put it in some vehicles that origially called for Mercon III (I put it in my 97 XR7) but I am unsure as to which transmissions are ok.
Old Apr 1, 2002 | 01:54 AM
Ponyracer's Avatar
Ponyracer
Transmission Fluid
You have an E4OD and should only use mercon, not the V. The E4OD/4R100 have not been changed to the new synthetic fluid yet. I would suggest using a Ford transmission filter though. I have seen some after markets that cause problems after a few miles.
Charlez- You had a 4R70W in your cougar and that was about the time that ford had a problem with torque converter shudder. The new mercon V fixed that, depending on mileage they changed the fluid and/or the converter.
Jim
Old Apr 1, 2002 | 08:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Transmission Fluid
>yet.
Just to clarify this statement - synthetic is fine in the E4OD/4R100, but ONLY MERCON synthetic. MERCON V is a no-no in these transmissions according for Ford.
There are conventional, synthetic blends, and full synthetic MERCON and MERCON V fluids available.
Mark
Old Apr 1, 2002 | 03:25 PM
scionti 94's Avatar
scionti 94
Transmission Fluid
Appreciate the information. I will make certain that only Mercon replaces the existing fluid in addition to the utilization of a Ford filter. Your input has been extremely helpful.
Tampa Bay
Old Apr 1, 2002 | 06:27 PM
Lightning2Fast's Avatar
Lightning2Fast
Transmission Fluid
Old Dec 24, 2007 | 01:02 AM
wstenger's Avatar
wstenger
I've been reading the posts and responses re:Mercon/MerconV. Is there any harm in my having just dumped 13+ quarts of DexronIII into the trans of my 1999 E350 with a 5.4L gas engine (think it has an E4OD)? I drained the converter as well (pipe plug in converter housing), think it should take 15qts?
Will
Old Dec 24, 2007 | 09:09 AM
Mark Kovalsky
It depends what transmission you have. Some 5.4L have the 4R100 and some have the 4R70W. It's fine with the 4R100, but it doesn't have an anti-shudder additive that the 4R70W MUST have.
Look at the blue tag in the driver's door opening. Under TR there will be either an E or a U. U is 4R70W and E is 4R100.
Old Dec 24, 2007 | 09:15 AM
bfloyd4445's Avatar
bfloyd4445
I put mobil one synthetic in my 93 bronco that I bought new at 30k and it has yet to be changed. The guy I sold it to has 285,000 miles on it without a single problem. He did countinue to use mobil one full syn in the engine as well. Mine had the 5.0, great truck, sometimes I wish I still had it. I highly recomend a full synthetic transmission fluid in that E4OD transmisson or EOD.
brentkhack
Apr 17, 2014 04:01 PM
AmmoDawg
Jan 8, 2013 09:26 AM
Bananarama
Jun 27, 2011 03:27 PM
50stang
Oil & Lubrication
Feb 21, 2005 07:43 AM
ruby2
Oil & Lubrication
Mar 14, 2003 09:16 PM
