Has the Mercon vs Mercon V for the 4R100 debate ended?
I know Mercon V has been approved for a long time now. So has most everyone finally agree that Mercon V is "safe" or not. At the beginning some stated Mercon V didn't work for them. I think Ford changed Mercon V a little bit to ease those concerns. So basically who refuses to switch? I am still using Mercon and will be doing a transmission fluid change again in 6k miles. Just getting ready to buy fluid again and like the current state of this debate.
It's more likely that their 4R100 trannys had issues to begin with and the fluid/filter change was the final straw that killed it. Using Mercon V instead of Mercon was just some convenient place to lay the blame. Those same trannys could've failed just as easily had the change been done with straight Mercon. There is just no way to know for sure. But if there was only 1 failure for every 100,000 successful fluid changeovers, then I'd say the numbers favor using Mercon V.
in short:
yes, the debate has been settled.
i also asked mark K. directly.
https://www.ford-trucks.com/forums/1...l#post13635046
IMO, there should be no debate.
in short:
i think the advantage is with Mercon V you can buy a fluid which has been tested and approved by Ford.
whereas, with Mercon, you cannot.
that is to say, you know Mercon V is the right stuff if the bottle has the Ford approval number on it. Mercon is no longer being tested by Ford, so you have to trust the manufacturer when it says it is the right stuff and is compatible.
now, whether the Ford certification means much to you or not is up to you.
expy37at
1997-2006 Expedition & Navigator
05-25-2011 11:05 PM
