Sponsored by: Real Truck
strange ecm problem
Old Apr 12, 2006 | 01:29 PM
Meanie's Avatar
Meanie
strange ecm problem
my truck is a 1999 f350 4x4 with the v-10, Ive been troubleshooting the dreaded miss problem and finally the truck stalls and then when restarted runs great. when trying to retrieve codes, the scanner cannot connect with ecm and there is no power at the test plug.
here's a list of what happens:
truck misses lightly,
stumbles,
then dies or sometimes only idles until accelerator is pushed then chugs w/ no power, and dies soon after.
heavy black smoke form exhaust during the chugging.
check engine light only when chugging.
fuel pressure normal and air filter is clean, new plugs installed and 1 new coil pack due to blown out plug on #5 2 weeks ago.
any ideas?
Old Apr 12, 2006 | 02:03 PM
FortyFords's Avatar
FortyFords
Did you chk fuse 3?
That powers the dlc link connector.
The plug blew out ,did you replace all plugs with same as stock ?
Rich
Old Apr 12, 2006 | 07:43 PM
Meanie's Avatar
Meanie
power to the dlc plug is now intermittent, no codes and the plugs were replaced but not stock, I just bought new ones but have no clue if that will fix it. sounds to me like a plug though.
it misses intermittently now though but since its not throwing a coil code it must be a plug or boot. any other suggestions?
Old Apr 12, 2006 | 10:29 PM
FortyFords's Avatar
FortyFords
Okay,its a known fact that these triton engines don't like aftermarket plugs.
we 've had many people try to use them and had the problems your having.
Bosch ,ngk and a few others i can't think of right now have caused intermitent misfires.
I'm not saying this the total problem you have.
Give it a try ,put the stock plug s(new of course) back in .
Rich
mikerans
Bronco II
Nov 17, 2012 09:31 AM
Krazymaan
Apr 24, 2010 11:14 PM
kenlee
Sep 21, 2009 02:08 AM
ihuntelk
Dec 30, 2007 08:17 PM
bruteboy
1997 - 2003 F150
Jun 16, 2005 03:37 PM
