Dual Locking Gas Caps / Same Key?
Old Jun 4, 2009 | 08:42 PM
shooer's Avatar
shooer
I've spent the day trying to locate a set (2) of locking gas caps that are keyed alike. No luck! I've seen sets before made by Stant. I tried all the standard parts houses ( Pep Boys, Kragen, etc. ) Even on line no one lists sets. LMC, Rock Auto, Amazon and Napa........no joy. Stant does not list any sets nor do they sell on line. I need a new cap and I'm really sick of having different keys for each of my dual tanks.
Any sugestions boys?
Don
Old Jun 5, 2009 | 12:44 AM
dakonthemountain's Avatar
dakonthemountain
I tried the same thing a number of years ago... No luck. Ended up keeping the two different keyed ones. .... I would also like to find two the same! Sorry I couldn't help!
Dak
Old Jun 5, 2009 | 05:44 AM
Jermafenser's Avatar
Jermafenser
Aftermarket gas caps don't offer two caps keyed alike AFAIK.
Only factory locking gas caps do, like on my '78 F150.
Old Jun 5, 2009 | 06:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975/79 F100/350 Locking Fuel Cap Sets -Keyed Alike / Use with Dual Tanks
Any suggestions boys?
The original Ford/Motorcraft locking fuel cap sets used with dual fuel tanks were keyed alike.
These sets were not available with one in-cab tank, one fuel tank on the drivers side of the bed.
Available only for the dual tanks mounted on the drivers side of the bed.
The sets came with two keyed alike keys.
1975/79 Stylesides: There are FIVE different types.
D5TZ9030B .. Locking Fuel Cap Set / VENTED / Use without Evaporative Emission (Motorcraft FC777) / Obsolete
Fits: 1975/76 F100/350
KINSEL L/M in Beaumont TX has TWO: 800-816-2894.
BOB ALLEN FORD in Overland Park KS has TWO: 800-676-0675.
MARLEY GROSS FORD in Spring Grove PA has TWO.
PARTS INTERNATIONAL in Farmers Branch TX has TWO: 888-727-0418.
FREESE MOTORS in Monticello IA has ONE: 319-465-3541.
D7UZ9030G .. Locking Fuel Cap Set / NON Vented / Use with Evaporative Emission only / (Motorcraft FC802) / Obsolete
PLEASANTVILLE FORD in Pleasantville NY has ONE.
CARL BEASLEY FORD in York PA has ONE.
GREEN SALES COMPANY in Cincinnati OH has TWO: 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has THREE: 606-787-5293.
D7TZ9030C .. Locking Fuel Cap Set / NON Vented / Use with Evaporative Emission only (Motorcraft FC803) / Obsolete
Fits: 1977/79 F100/350
RED TAYLOR FORD in Corning AR has ONE.
D7TZ9030E .. Locking Fuel Cap Set / NON vented / Use without Evaporative Emission (Motorcraft FC804) / Obsolete
Fits: 1977 F100/350 only.
No Ford Dealer or obsolete parts vendor has any.
D8TZ9030E .. Locking Fuel Cap Set / NON Vented / Use without Evaporative Emission (Motorcraft FC806) / Obsolete
Fits: 1978 F100/350.
TISON MOTOR COMPANY in Estill SC has ONE: 803-625-2551.
The sources I listed are the only ones that have any.
Make SURE if buying any of these, that both caps and the keys are in the box.
Make SURE the keys fit BOTH the caps!
Old Jun 5, 2009 | 08:23 AM
460me's Avatar
460me
Same here,best thing to do is get one of those color deal things that fit over the gas key and paint the cap the same color.
Old Jun 5, 2009 | 10:55 AM
Recoil's Avatar
Recoil
I got 2 that are keyed alike from Napa. Ask them next time you are there. They sell 2 cap packages.
Old Jun 5, 2009 | 11:02 AM
FordEdselFanatic's Avatar
FordEdselFanatic
Try taking your two caps to a locksmith, and see if he can make one key that will fit both caps.
Old Jun 5, 2009 | 07:41 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Stant also makes a keyed alike two cap set.
These are not very well made though and they have been known to fail California Smog Tests, brand new out of the package. Ask me how I know... []
Old Jun 5, 2009 | 09:00 PM
jason867's Avatar
jason867
I would guess most gas cap keys have double sided keys (so you can insert it either way). If you have two gas caps that share the same type of key, you could have a locksmith put two different carving patterns on one key. Insert it one way for one lock, the other way for the other lock.
that's assuming the tumbler doesn't engage both sides of the key at the same time (unlikely)
Old Jun 5, 2009 | 10:44 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
How do they test them with a vacuum pump or something?
Josh
Old Jun 6, 2009 | 01:40 AM
79Indy's Avatar
79Indy
Josh
Yep. I have a set of new unkeyed caps just for the test. I use my original Motorcraft locking caps(1 key) with the cracked gaskets the other 729 days.
Old Jun 6, 2009 | 06:07 AM
TexasGuy001's Avatar
TexasGuy001
I got a pair keyed alike off of ebay. The ones I got are made really well. They are a German made part. They also don't lock as soon as you install them, so you can leave them unlocked if you like. I think the ebay seller was this guy. I just asked him if I could get 2 keyed the same.
Locking Gas Cap Ford Pickup Truck E Van Excursion F150:eBay Motors (item 290264351655 end time Jun-26-09 13:17:54 PDT)
Thats cool what NumberDummy said. I didn't realize that you could get Mororcraft locking caps.
Old Jun 6, 2009 | 09:09 AM
Furyus1's Avatar
Furyus1
Can't be any worse than the ones I bought for my truck... Damn things are made out of plastic... Even the tabs that lock into the filler neck are plastic... I've already had to replace one of them after I dropped one and it fell apart when it hit the ground... The only metal on these caps are the big round cover pieces... Can't remember the manufacturer name off the top of my head but I think it's Motormite... Couldn't find any Stant's around here locally that would fit right for some odd reason...
Old Jun 6, 2009 | 12:15 PM
76f350spercamprspeal's Avatar
I am having the same problem.
I have a locking Metal Gas Cap on the AUX tank.
I have a plastic NON-Lockng on the MAIN tank (Which doesn't work,Has Huge hole in it,and it sucks because Super Camper Special tanks are bigger,so you have to get one out of another Super Camper Special.
I want Metal High Quality Keyed alike caps.
The ones I want are really big and the top is metal and its huge.
Old Jun 7, 2009 | 02:51 AM
NumberDummy
I have a plastic NON-Lockng on the MAIN tank, which doesn't work.
Has Huge hole in it, and it sucks because Super Camper Special tanks (1973/78: Only one fuel tank is specific to Super Camper Specials), are bigger, so you have to get one out of another Super Camper Special.
D3TZ-9002-V .. Aft Axle Fuel Tank, Plastic - 20 Gallon / Use without Evaporative Emission / Obsolete
Fits: 1973/77 F350 Super Camper Special.
D8TZ-9002-J .. Midship Fuel Tank, 22.5 Gallon / Use without Evaporative Emission / Obsolete / (D8TZ-9002-J replaced D3TZ-9002-B).
Fits: 1973/78 F350 Regular Cab and Super Camper Special / 1973/78 F100/250 Regular Cab 2WD.
Fits: 1977/78 F250 4WD Crew Cab.
BOB ALLEN FORD in Overland Park KS has ONE D8TZ-9002-J = 800-676-0675.
GREEN SALES COMPANY in Cincinnati OH has TWO D8TZ-9002-J = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has ONE D8TZ-9002-J = 800-546-7278.
WESLEY OBSOLETE PARTS in Liberty KY has ONE D3TZ-9002-B = 606-787-5293.
No other Ford Dealer or obsolete parts vendor has any.
Inline66
Apr 30, 2017 06:49 AM
soulnamja
WTB - Parts & other
Dec 13, 2016 02:32 PM
mkotalik
1997 - 2003 F150
Sep 26, 2016 11:42 AM
minke
Feb 23, 2016 01:07 PM
jsw0767
Oct 14, 2014 06:06 AM
