Adjustable Draglink
Old Jun 4, 2009 | 08:16 PM
robison37's Avatar
robison37
Adjustable Draglink
I just did a power steering swap on my 75 f250 with a 78/79 box. I am looking for a adjustable draglink for the pitman arm any ideas.
Old Jun 6, 2009 | 10:36 AM
lasthighboy's Avatar
lasthighboy
i think you can use a chevy drag link. has a adjusting collar and 2 seperate tie rod ends. you might have to ream your holes to match the chevy taper. check into it.
Old Jun 6, 2009 | 10:00 PM
robison37's Avatar
robison37
Thanks for the info.
Old Jun 6, 2009 | 10:25 PM
75F350's Avatar
75F350
is this truck lifted? IS a straight drag link gonna cut it? 78 / 9 aftermarketdropperd drag links are adjustable.
Otherwise just tap the two ends opposite directions so you can install left and right threaded tie rod ends.
IS crossover not a consideration? Much better than the push pull system.
F-250 restorer
24
Sep 8, 2015 03:36 PM
draglink
Aug 13, 2014 09:16 AM
draglink
Jul 4, 2014 07:28 PM
MIKEDENGINEER
May 9, 2014 07:50 PM
oldshep66
Jan 6, 2013 09:15 AM
