Lights "pulsing"
Old Nov 13, 2011 | 09:37 AM
flbmcman's Avatar
flbmcman
Question Lights "pulsing"
Hi all,
Back again, hopefully with an easier problem than the last.
When the truck is running, it appears that the dash/headlights are "pulsing".
Can't figure this out, as the alt. is attached to the batteries, which should act as a filter.
any thoughts?
thanks in advance
Lawrence
Old Nov 13, 2011 | 10:03 AM
1994F2507.3L's Avatar
1994F2507.3L
is this constantly happening or just for awhile after startup?
Old Nov 13, 2011 | 10:51 AM
flbmcman's Avatar
flbmcman
constant, not like the gp controller cycling
Old Nov 13, 2011 | 02:55 PM
vfelix702's Avatar
vfelix702
try a voltage regulator its mounted on the passenger fender
Old Nov 13, 2011 | 03:34 PM
Aune163rd's Avatar
Aune163rd
The big silver box is what he is talking about if you dont know...
Old Nov 13, 2011 | 05:56 PM
starmilt's Avatar
starmilt
Before buying any parts, unplug the voltage reg and jump the a and f terminal on the wiring harness to test the alt. If it is still serging you know for sure it is not the regulator.
I would then clean all connections, if the problem persists then pull the alt and have it tested.
Old Nov 13, 2011 | 08:01 PM
84-6.9L's Avatar
84-6.9L
Check your whole alt harness, mine would do the same thing, I found the whole harness had burned wires and such. Take a look at it and check and recheck your grounds as well.
Old Nov 15, 2011 | 08:43 AM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
I get that too but with my taillights.. if my headlights are on (break lights come on) and when the signal light kicks on and off one goes brighter but they all bling (plate light and both tail lights) the signal light side kicks brighter tho. any ideas?
Old Nov 15, 2011 | 09:32 AM
farmert's Avatar
farmert
Rollin-- Check the grounds for the tail lights. Sounds like it is not making good contact.
1979 300i6
Apr 27, 2013 11:59 PM
kell2784
Nov 6, 2009 02:31 AM
afinepoint
Electrical Systems/Wiring
Oct 25, 2009 10:49 AM
rmalottwtes30
25
Jan 2, 2009 09:33 PM
ontario ford guy
Sep 3, 2002 02:52 PM
