remote start instal
Old Jun 2, 2009 | 09:12 PM
dalekstephens's Avatar
dalekstephens
remote start instal
i am looking for some info for installation of a stellar remote start for a 2006 f250. can you tell me the color of the wires and locations to access. thanks
Old Jun 2, 2009 | 11:42 PM
06F25060L's Avatar
06F25060L
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS Yellow Ignition harness +
IGNITION Red/green Ignition harness +
IGNITION 2 Blue/green
This wire is only required on the V-10 Gas engine.
ACCESSORY Red/black Ignition harness +
ACCESSORY 2 Gray/yellow Ignition harness +
STARTER Dk.green Ignition harness +
KEY SENSE Black/pink In airbag plug on right side of st. column -
TACH SIGNAL Use an injector
DIESEL TACH SIGNAL Green/white SEE NOTES
Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the green/white among these wires.
LOCK White/red In harness above gas pedal +
On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink/yellow for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel.
UNLOCK Black/white In harness above gas pedal +
DRIVER LOCK MOTOR Pink/black In harness above gas pedal +
DRIVER UNLOCK MOTOR Red/orange In harness above gas pedal +
PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal +
GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER
DOORPIN Black/blue Above parking brake in DKP +
The vehicle’s computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions.
FACTORY ARM Yellow/black Above parking brake in DKP -
This is the driver’s doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm.
FACTORY DISARM Dk.green/purple In harness above gas pedal -
BRAKESWITCH Green At switch above brake pedal +
PARKLIGHTS Brown At light switch harness +
HAND BRAKE Lt.green/red At plug above handbrake lever -
HORN Dk.blue In airbag plug on right side of st. column -
jimbomitch
29
Apr 4, 2018 07:56 AM
Cdy1
2009 - 2014 F150
Nov 24, 2013 08:48 PM
Powerstrokin_350
Nov 2, 2009 11:37 AM
E-WA
Dec 16, 2004 05:39 PM
